Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Flashed by a traffic light camera...  (Read 14236 times)
Re: Flashed by a traffic light camera...
« Reply #30 on: 12 October 2010, 14:59:09 »
You're right, of course - it wouldn't be any defence in court, at all.. and generally speaking I try to drive to accommodate the people in front of me, behind me, and beside me - I've had too many close calls in my (relatively short, I suppose!) time behind the wheel to assume anyone else on the road has half a clue about how to drive  ;D
Yep, especially if "pressing on" in a slightly less "miss daisy" fashion. It's not what you do so much as the r.sole behind / in front / waiting at the next junction is about to do that's worrying.
Accordingly, If approaching lights with someone right on your tail it's probably best not to put yourself in a position where heavy braking is required.
Easy to say until you find you've done just that, of course. ::)
« Reply #31 on: 13 October 2010, 01:31:38 »
Nope, nobody about. Lights had been green for ages, got to a point where I couldn't stop on time if they had changed and put me foot down to make sure....ching ching...'dangle berries'!  :(
« Last Edit: 13 October 2010, 01:33:07 by chrisgixer »
skyblue
  • Bracknell
« Reply #32 on: 13 October 2010, 09:31:38 »
I was once flashed by the same camera yrs ago and never heard a thing from it so lets hope you have the same good luck too
« Reply #33 on: 13 October 2010, 09:34:03 »
I had same a while back, i was actually on the bike, when they changed on a 60 limit dual carriageway near Oxford, twist and go felt better option, it was red just after my front wheel crossed the white line, i never heard anything. I think they are only set to enabled a couple of seconds after the lights change
« Reply #34 on: 13 October 2010, 09:52:17 »
Yeah, I have been flashed several times on the bike and heard nothing in two weeks. One was so renowned for flashing everyone we used to set it off on purpose. 5 bikes 10 flashes.  ;D
But these lights where defo green, never saw an amber much less red, and I was watching them like a hawk. So it was definitely speed that tripped it....and given it's a more up to date system I don't think there is much chance it had "run out of film"...wonder if I can bribe the postman to loose the letter? Will that work? :-/.  :D
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #35 on: 13 October 2010, 10:21:01 »
It's only an SP30, shouldn't make much (if any) difference to your insurance premium.  Yeah there's a £60 fine, not that bad really is it?
Budget tyres, false economy.
« Reply #36 on: 13 October 2010, 10:54:42 »
Sp 50.
« Reply #37 on: 13 October 2010, 11:04:29 »
.... I think they are only set to enabled a couple of seconds after the lights change
Isn't that what the amber is for?  ::)  :y
« Reply #38 on: 13 October 2010, 11:11:37 »
I mean when its changed to Red.... i've stopped before to see people go through a good few seconds after its gone Red, and not seen the camera go off  :-/
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #39 on: 13 October 2010, 11:12:46 »
Sp 50.
You sure?
Reason I ask is that I got an SP30 two years ago for doing 72 in an 50.  I didn't realise it was a 50 because it was it was an unfamiliar area to me and a road diversion had led me to that dual carriageway (at night too), the previous dual carriageway I had been on was NSL.  I got pulled over by (armed!) police at a nearby slip road.  In one sense I was peeved that I got pulled when the roads were clear at night and wasn't aware about the 70>50 change, apparently due to shorter slip roads?  But I was also fairly lucky as had I been going 3mph faster it would have been a court case!
In any case, best of luck and hopefully no bad news.
« Reply #40 on: 13 October 2010, 11:15:55 »
Something not right there, 70 in a 30 would be a ban, so you should have had sp50 I would have thought...?
« Last Edit: 13 October 2010, 11:16:52 by chrisgixer »
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #41 on: 13 October 2010, 11:20:26 »
The limit was 50 on this particular dual carriageway, having been diverted from a 70mph dual carriageway due to roadworks.
I never speed in 30/40 zones, especially as they're built up areas.
« Last Edit: 13 October 2010, 11:23:00 by Shimmy »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #42 on: 13 October 2010, 11:27:49 »
I got flashed a few years ago doing 94mph in a 70 dual carriageway,got away with an sp60 for that as it was a first(and only) offence.I had a £60 fine and 3 points which are finished now
other rides
« Reply #43 on: 13 October 2010, 11:32:03 »
It'd be an SP30, Chris, if you do get done:
SP30      Exceeding statutory speed limit on a public road      3-6
SP40      Exceeding passenger vehicle speed limit      3-6
SP50      Exceeding speed limit on a motorway      3-6
From: http://www.direct.gov.uk/en/Motoring/DriverLicensing/EndorsementsAndDisqualifications/DG_10022425
ISTR a lot of people were incorrectly given SP50s a few years back when they should have been given SP30s - there was an appeals procedure put in place when it was realised.. 'course now I can't find a link to back that up  ;D
« Reply #44 on: 13 October 2010, 11:40:31 »
Ah, ok. Was under the impression the number related to the speed limit concerned....
Pages: 1 2 [3] 4 5 6   Go Up
