Author Topic: old gm clutch removal  (Read 2700 times)
tidla
  • solihull
« on: 06 November 2010, 22:16:30 »
how come the idea didnt catch on, slide the spline out the way. take the clutch out thru a cutout in the bell housing??
http://cgi.ebay.co.uk/VAUXHALL-CLUTCH-TOOL-PULLER-AND-SLIDE-HAMMER-PLUS-CLIPS-/140472426675?pt=UK_Measuring_Tools_Levels&hash=item20b4cf20b3
Re: old gm clutch removal
« Reply #1 on: 06 November 2010, 22:33:37 »
Clutch on an Astra F was apparently a 30 min job including boiling the kettle, same with the last Cavalier before it became a Vectra.
Clutch on an Astra G involved lowering the front subframe - been there done that
Progress eh!!
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #2 on: 07 November 2010, 09:01:26 »
My first car was a Mk. I Astra, that had the plate on the bellhousing to facilitate easy removal of the clutch assembly, I also had a Mk. II Ashtay ('H' reg.) that didn't have a plate.
Having also had a few Cavaliers from around the mid nineties I can also say they never had the plate...
2woody
  • Northumberland
« Reply #3 on: 07 November 2010, 20:57:02 »
i can't really understand why they did it in the first place - it can only have cost them money to do - extra components to produce.
designing cars to be easy to work on is never a good idea for a manufacturer
tidla
  • solihull
« Reply #4 on: 07 November 2010, 20:58:59 »
your thinking of renault ::)
andyc
  • Norfolk
« Reply #5 on: 08 November 2010, 10:16:49 »
Mk2 Astra 1.8i done in thrity mins from stopping the car to driving out of the workshop
The reason they stopped it was because they had to make the flywhell heavier due to the EU Emission rules. The only way they could do this was to make the flywheel thicker, couldn't make it any bigger in dia' as the bellhousing wasn't big enough
Andy
Thetford. Norfolk
Welung666
« Reply #6 on: 08 November 2010, 11:18:31 »
Andy
I'm also pretty sure the flywheels on the quick change were stepped aswell so the friction plate was sunk into the flywheel.
andyc
  • Norfolk
« Reply #7 on: 08 November 2010, 16:14:00 »
on the very last one they were but the flywheel was so thick that it filled the drop out hole.
One things like Nova, Astra, Cavalier etc it was just a normal flat flywheel
Andy
Thetford. Norfolk
« Reply #8 on: 08 November 2010, 18:43:39 »
Last of the cavs had a pot flywheel so you could not change them without box removal
Welung666
« Reply #9 on: 08 November 2010, 20:47:23 »
There you go then, I got it back to front ;D
unlucky alf
  • worksop, notts
« Reply #10 on: 08 November 2010, 21:05:08 »
Had to do the brother-in-laws clutch on his astra last month & that is when i found out about the pot flywheel >:(, managed to unbolt the g/box & move it enough to let the clutch drop out without removal of driveshafts. :y
