Pages: 1 [2] 3  All   Go Down
Author Topic: It Failed!!!!!  (Read 6526 times)
Re: It Failed!!!!!
« Reply #15 on: 18 November 2010, 18:41:47 »
007 Nearside rear braking system leaking (BURST ON TEST) ....
I assume that this MOT station also does repairs.  :-/ It does seem rather coincidental  :-?  :-?  :-?
In 30yrs of owning a car I've never had a brake hose burst, they've needed replacing due to being perished, but to burst on a car as old as yours ...... :-/  :-/  :-/  :-/
Re: It Failed!!!!!
« Reply #16 on: 18 November 2010, 18:54:53 »
Did it fall, or was it pushed?  :-?
Re: It Failed!!!!!
« Reply #17 on: 18 November 2010, 19:47:53 »
Exactly!  ::)  ::)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: It Failed!!!!!
« Reply #18 on: 18 November 2010, 19:47:56 »
I have seen several pipes burst on test over the years, mainly pipes that are hidden by exhaust shields and the like and mostly on renaults :D
other rides
Re: It Failed!!!!!
« Reply #19 on: 18 November 2010, 19:51:13 »
It does seem a coincidence though that Mr MOT man failed most lengths of brake pipe due to 'rust' on a car somewhat newer than mine, and then a pipe just happens to burst on test too?  :-?  :-?  :-?
henryd
  • west cornwall
Re: It Failed!!!!!
« Reply #20 on: 18 November 2010, 19:54:47 »
true I suppose :P
other rides
Re: It Failed!!!!!
« Reply #21 on: 18 November 2010, 19:58:21 »
true I suppose :P
Having just looked at Dan's profile, his car just looks somewhat newer ::) but is only a year newer  ;)
Omega_Dan
Re: It Failed!!!!!
« Reply #22 on: 19 November 2010, 08:36:09 »
From what the tester said (a friend of the family by the way) he was going to fail it anyway on the corrosion but when he did the nearside brake test it ruptured. He said everything else on the car was good and it was just the rear brakes.
Omega_Dan
Re: It Failed!!!!!
« Reply #23 on: 19 November 2010, 08:55:37 »
Dan, I can whip all those pipes off the MV6 I'm breaking and send them up to you, I'll even sling you a zorst rubber in with them :y
Lee you have a PM :y
Welung666
Re: It Failed!!!!!
« Reply #24 on: 19 November 2010, 13:11:48 »
I've got it, let me have a look on this breaker in the morning and I'll PM you back ;) :y
Omega_Dan
Re: It Failed!!!!!
« Reply #25 on: 19 November 2010, 15:07:33 »
cheers lee. ill be online sometime tomorrow aftermoon :y
neilr
  • Barnet, Herts
Re: It Failed!!!!!
« Reply #26 on: 19 November 2010, 17:07:28 »
Sorry it failed Dan. As a side note took my daughters 206 for test earlier in the year it too failed on brake pipes and hoses. Tester said hoses wer bad and could burst however even with had push on pedal for a long period it held. Make me wonder about yours. when i took 206 ones off could see braiding beneath rubber but no sign of fluid loss.
Re: It Failed!!!!!
« Reply #27 on: 19 November 2010, 17:08:27 »
I hope you get everything sorted Dan and end up with good news! :y :y
Omega_Dan
Re: It Failed!!!!!
« Reply #28 on: 20 November 2010, 17:35:10 »
Cheers, just frustrating i cant drive it. Lee may have some used pipes / hoses for me so i can get back on the road asap :y i hope ;D ;)
Welung666
Re: It Failed!!!!!
« Reply #29 on: 20 November 2010, 19:13:37 »
I haven't had chance to get under it today, I'm under there tomorrow so will check :y
Pages: 1 [2] 3  All   Go Up
