Author Topic: Rigid Towing bars  (Read 3285 times)
Re: Rigid Towing bars
« Reply #1 on: 30 November 2010, 12:47:18 »
I suppose it depends what you are towing and how far. I bought an A frame and its been brilliant  ;)
« Reply #2 on: 30 November 2010, 12:48:31 »
A miggy, about 30 miles
Welung666
« Reply #3 on: 30 November 2010, 12:49:09 »
They aren't bad Rob but you need a 2nd person to steer the towed car. I also have an A-Frame and it's a doddle to setup and use :y
  • Online Online
« Reply #4 on: 30 November 2010, 16:32:29 »
These any good for towing a Mig?
http://cgi.ebay.co.uk/HEAVY-DUTY-towing-bar-sping-loaded-damper-car-tow-rope-/380098472310?pt=UK_Recovery_Tools&hash=item587fa26976
It looks very similar to Machine Mart's, if it's the same they're not that good. When mine folded itself in half by the spring I borrowed a solid home made bar, .... far better.
But an A frame is better still.  :y
Omegatoy
  • UK
« Reply #5 on: 30 November 2010, 21:01:53 »
got to say the person driving the towedcar has to keep the bar reasonably straight or it can bend,
mine has towed a fully laden transit twin wheel high top 45miles no problem, it also towed a transit transporter with a mondeo on  the bed no worrys, the mig didnt even break into a sweat either!! :y
bestie26
  • bradford , west yorkshire
« Reply #6 on: 02 December 2010, 21:21:39 »
ive got a homemade one made from a scaffolding bar with a "D" link (think thats what they are called)  welded to each end ive towed loads with it including a transit van and found it a lot better than the shop versions
unfortunatly its a bit bent now thanks to my mate as i towed a car up my drive and turned left onto main road and the tit forgot to take the steering lock off! resulting in a smashed bumper and a bar thats now shaped like the front of a mondeo (still tows ok tough)  :y
« Last Edit: 02 December 2010, 21:22:09 by bestie26 »
Kneepad
  • West Scotland
« Reply #7 on: 02 December 2010, 23:03:58 »
 ;D ;D ;D ;D  I love it.
david036
  • Lancashire
« Reply #8 on: 04 December 2010, 10:57:00 »
Sorry to go off topic slightly, Do you get any damage to the towing car whe using the A-Frames?  It just seems from looking at them that there could be some damage done to the bumpers?
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
  • Online Online
« Reply #9 on: 04 December 2010, 14:15:31 »
I suppose you could do if the car was any lower than an Omega, the lower rubber strip on an Omega was just compressed when I used an A frame to tow one. No damage done though.  :y
david036
  • Lancashire
« Reply #10 on: 04 December 2010, 14:25:50 »
Ah thanks for the reply Andy B!  That does make perfect sense to have two cars ideally the same height!!!
  • Online Online
« Reply #11 on: 04 December 2010, 14:49:48 »
It doesn't quite work like that  ;). The tow ball of the towing car is generally the same height from the road no matter what car it is,  the towed car is connected to the A frame via the lower wishbones so what determines whether the A frame will rub is the relationship between the height of the lower wishbones to the height of the bottom edge of the front bumper from the ground.  :y
vauxfan2k
  • Western Isles
« Reply #12 on: 04 December 2010, 15:09:16 »
we used a tow dolly to take this car the 70 odd miles up to my place, needless to say there was no tailpiece left on the exhaust when we got home  ;D ;D ;D
