Author Topic: 30 i omega power calibra help  (Read 2748 times)
marke
  • manchester
« on: 04 December 2010, 22:35:52 »
freind has calibra with mig 30 i in it when it get hot aal power is lost any ideas :y
Re: 30 i omega power calibra help
« Reply #1 on: 05 December 2010, 16:11:04 »
Nope, didn't understand a word of that....
« Reply #2 on: 05 December 2010, 18:13:36 »
don't think i've seen such a short post with so many spelling errors! Translating into English i think it reads, a friend has Calibra with 3.0 V6, when it gets hot all power is lost.
marke, it might have helped if you proof read the post first  ::)
Any codes stored?
« Last Edit: 05 December 2010, 18:14:04 by tunnie »
« Reply #3 on: 05 December 2010, 18:45:18 »
Read the fault codes first!  :y
Martin_1962
« Reply #4 on: 05 December 2010, 18:52:04 »
Should have left the engine in a proper car!
    • 530D M Sport, 330i Coupe
« Reply #5 on: 05 December 2010, 19:00:57 »
Calibra's are great cars, one of my all time favourites  :y
vauxfan2k
  • Western Isles
« Reply #6 on: 05 December 2010, 19:07:33 »
ill hazzard a guess at the crank sensor, seeing as the heat will be cooking the sensor wiring, altho seeing as its been squeezed into a calibra, there is no way of knowing or telling what wiring, ecu, engine components have been used.
Either need more detail or try a calibra forum
Martin_1962
« Reply #7 on: 05 December 2010, 23:43:50 »
Yes but an Omega had to die to do this.
There are too many wrong wheel drive cars as it is.
Kneepad
  • West Scotland
« Reply #8 on: 06 December 2010, 11:02:21 »
As said earlier, you should check for any error codes and then post them here.
Link to paperclip test:
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #9 on: 06 December 2010, 11:17:02 »
From memory, Calibra has a 10 pin diag socket, so will need to check pinouts first.
marke
  • manchester
« Reply #10 on: 06 December 2010, 19:27:18 »
sorry all posted just as i was going work
« Reply #11 on: 06 December 2010, 20:10:04 »
ALDL type connection then. Should be able to blink codes out without too much of an issue.
« Reply #12 on: 06 December 2010, 20:30:59 »
Hmmm, perhaps the Omega was already dead? Besides, 3.0 Vectra's and Calibra's are great cars, GM really missed an opportunity not dropping the 3.0 in at the factory....
As far as wrong wheel drive goes.... Hmmmm, I don't think 99% of drivers give a stuff which wheels are driven. Yes, on here we all love the way big heavy RWD cars drive and handle but not all FWD cars handle poorly.
