Author Topic: Focus TDci Cold starting problem .....  (Read 1664 times)
I_want_an_Omega
« on: 25 November 2010, 08:52:51 »
Hi,
SMBO has an '04 1.8 Focus TDci. The last couple of (cold) days it hasn't started first time.
I tried cycling the glowplug light this morning a total of 6 times before starting - it was no better and would only start on the 2nd crank of the engine.
Any ideas, glowplugs?
Thanks
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: Focus TDci Cold starting problem .....
« Reply #1 on: 25 November 2010, 09:30:01 »
i would geuss glowplugs, right time od year for them!
Warning: Dates in Calendar are closer than they appear.
« Reply #2 on: 25 November 2010, 11:08:00 »
Could be many things, the fact it catches on the second go hints at not being glowplugs but, test them anyway.
Air in the system gives similar symptoms, its worth checking the pipes for slight leaks and maybe changing the fuel filter.
These also suffer from injector issues (leaking) and cam sensor failures (often causes conk out when driving to!)
There also very susceptable to failing batteries!
« Last Edit: 25 November 2010, 11:08:38 by Mark »
I_want_an_Omega
« Reply #3 on: 08 December 2010, 16:38:13 »
It was the glo-plugs, all of them open circuit.
New set of 4 fitted, problem sorted  :y
