Author Topic: My snow chains have arrived.....  (Read 4584 times)
« on: 07 December 2010, 23:37:08 »
How do you fit them? the instructions are not very clear, but do say that you put them behind the wheel, is there a break to enable this? :-?
I dare not take them out of the container or I will never get them back again ::) ::) ::)
Re: My snow chains have arrived.....
« Reply #1 on: 08 December 2010, 00:16:26 »
I had a play with mine... Take them out of the box and make sure they aren't tangled ;) ;)
I found the pictures on the box more use than the instructions :y
Kneepad
  • West Scotland
« Reply #2 on: 08 December 2010, 00:16:29 »
There will be. Lay them out flat and drive onto them then join up with whatever fixing device there is.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #3 on: 08 December 2010, 08:03:41 »
what type did you get??
Solar charger fitted.
If not Broke dont fix it..
« Reply #4 on: 08 December 2010, 09:31:39 »
practice in a warm garage.. if you wont be able to (I wasnt :-[) no chance in snow!
smithpa7
« Reply #6 on: 08 December 2010, 12:17:22 »
I took my spare wheel into the nice warm garage :y
I then practised fitting them. Within 5 minutes it was done.
I agree entirely with Lazydocker, the picture is the best way to understand how to fit them.
I would attach a picture, however I can't understand the instructions ::) ::)
« Last Edit: 08 December 2010, 12:18:12 by smithpa7 »
hoofing it
« Reply #7 on: 08 December 2010, 13:28:27 »
I was at tyre fitter getting 2 new boots yesterday when a muppet came in to ask the fitters to check to se if he had fitted the snow chains correctly as he kept slipping.
Much to our horror he had bought which can only be described as a fishermans net with bungee cord and they were shredded.
The chap had also wrecked both C.V boots and burst a flexi.
I felt sorry for the now tyre fitter/mechanic who had to untangle/cut them off.
Debs.
« Reply #8 on: 08 December 2010, 14:48:06 »
Practice...practice.....practice! ;)
Most can be fitted easily, after laying-out/untangling first.
The swaged cable joint-ends usually go at the top-inner of the tyre`s shoulder (slide the straightened chain-set, in from the rear of the car and then reaching each hand around the side of the tyre and picking up an end of the cable).....the chains and outboard securing band/link are pulled outwards (around the tread/outer-side-wall), the outer ring joined (usually with a link) and adjusted until the set is sitting evenly and tightly: some tension using a rubber-link, coil-spring or (like mine) a ratchet to tighten.....there`s usually no need to jack or rotate the wheel when installing; although sometimes when removing the set, the joint is in the wrong spot and you may need to move the car a bit to reposition it at the top of the wheel for easy undoing.
It really is easy....once you`ve managed to do it properly (twice) you`ll wonder why it ever seemed tricky before! :y
I can fit mine in two minutes per wheel, whilst in deep snow and lit just by flashlight; but, the first couple times of use took a fair-bit longer.
You`ll be amazed at where you can go (even on sheet ice hills) with chains....enjoy. 8-)
Annotated pic showing typical chain parts:
smithpa7
« Reply #9 on: 08 December 2010, 17:12:07 »
Also it is advisable to keep under 30mph when using snow chains. Unless you have bought the very expensive Thule's for £371 :o :o :o
« Reply #10 on: 08 December 2010, 17:15:19 »
Absolutely. In fact, I'd say if you can get anywhere near that speed you need to pull over and remove them. If they break and start flailing around they will do plenty of damage at that speed.
I view them as something to get out of the boot when you get stuck, and put away again as soon as you are back on the move.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #11 on: 08 December 2010, 19:55:16 »
But stop the car before removing them, eh Kevin?  ;D ;D ;D
« Reply #12 on: 08 December 2010, 21:17:48 »
http://www.youtube.com/watch?v=C6VqK9Ej9SQ&feature=related
CEM......Brilliant :y :y :y :y :y :y :y :y :y :y :y :y
Thank you all for your comments, if it warms up I may have a play at the weekend, assuming I do not have to find out the hard way first ::) ::)
Me thoughts on them are indeed simply a 'get me out' tool to be removed once on my way, having stopped the car first ;D ;D
« Reply #13 on: 08 December 2010, 21:52:48 »
I'll be happy if it helps :y :y :y :y
r1
  • nottingham
« Reply #14 on: 09 December 2010, 10:24:42 »
bet it doesnt snow again now you have them!!!!
Page created in 0.022 seconds with 21 queries.
