Author Topic: Auto Gearbox Warning  (Read 2270 times)
Squealey
  • Donington, Lincs
« on: 19 December 2010, 11:58:49 »
Went out to collect my daughter last night and even though we havent got snow up here it is still bitterly cold. Stuck the auto (AR35) gearbox in first so it would warm up a bit quicker and went along at approx 30-35 at 3500 revs. After about a minute of this I had a warning on the dash saying 'Automatic Gearbox'. I dropped it into drive and carried on as usual.
From then on pulling away at junctions it was like it was in snow mode (which it wasnt). Got to my daughter, switched the engine off and back on again and all was well again.
Cars absolutlely fine now, just wondering why it does this? Is it some sort of safe mode if the gearbox temperature gets too hot? (and no I wont be trying to replicate it any time in the future)
Re: Auto Gearbox Warning
« Reply #1 on: 19 December 2010, 12:01:48 »
From then on pulling away at junctions it was like it was in snow mode (which it wasnt).  ....
Effectively is was in snow mode. The fault warning had put the gearbox into 3rd, which is what snow mode does.  ;)
Can't help with your fault though.  ::)
« Reply #2 on: 19 December 2010, 12:34:50 »
It should cope with those conditions so there's something amiss, but why select first ? Never felt the need personally.
Anyway, if the ATF has been serviced within the last 50 to 60 k then I'd be looking to get it on tech 2 asap. Which might be awkward given your location.  :-/
« Reply #3 on: 19 December 2010, 12:47:57 »
In practice that's what the gearbox does for itself anyway ie when cold hang on to first for a bit longer than usual, it's to help get the cats up to temp sooner .... so they say.  :y
bluey
  • West Mids
« Reply #4 on: 19 December 2010, 23:43:19 »
Yep, and get the internals up to temperature quicker too.  Been a standard feature on many auto's for a good few years now, so there's no need to do it yourself.
Ian_D
  • York
« Reply #5 on: 20 December 2010, 10:22:50 »
Its a pain in the bum if you ask me...
7am in the morning, and im leaving my housing estate at 3500 rpm! (Snow button here I come!)  ::)
[size=12]
« Reply #6 on: 20 December 2010, 17:52:56 »
The ATF was replaced when the AR35 went on (around 120k).
Given how hard the tractors work the ATF, esp chipped ones, I'd probably change it at least every 50k.
However, in this case, I am not immediately suspicious of the box.  If you have a repeat, get a reader on the gearbox ecu :y
Squealey
  • Donington, Lincs
« Reply #7 on: 20 December 2010, 21:49:29 »
Shes been good as gold since, hasnt missed a beat, so i'll just not do that again and monitor the situation from now on.
