Author Topic: Peugeot 206 help request  (Read 2101 times)
kevinminton
« on: 11 November 2010, 21:25:04 »
Thanks to Daz's help the Omega is now off the "attention needed" list.
Which means my attention turns to Son's 206 (2002, 1.6 16v). Does anybody (a) have some experience of these or (b) know where I can get fault codes read easily in West Midlands?
Current symptoms are intermittent very rough running (lumpy 3 cyl) with "Anti Pollution Fault" display. A quick scan of P206 forums shows no obvious common culprit. Changed plugs already.
When you look at other car forums it reinforces just how good OOF is  :)
TIA
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Peugeot 206 help request
« Reply #1 on: 11 November 2010, 22:05:37 »
coil pack is a common fail on them as is the injector loom which can break up and switch off an injector
« Last Edit: 11 November 2010, 22:06:19 by henryd123 »
other rides
Welung666
« Reply #2 on: 12 November 2010, 06:08:02 »
I've got a generic code reader here if that's any use? I'm over near Merry Hill :y
neilr
  • Barnet, Herts
« Reply #3 on: 12 November 2010, 17:11:16 »
no 4 injector prone to fail too daughter one has done that. 206 forum is crap though
kevinminton
« Reply #4 on: 12 November 2010, 17:17:59 »
thanks all - the pointers are consistent with the symptoms so I'll have a look at the weekend.
Welung666
« Reply #5 on: 21 December 2010, 20:23:46 »
Wel just over a week ago I went over to Kevin with the ELM325 and the lappy. A whole list of missfire codes and a couple of non-sensicle codes all showing as not present. A little investigatory dismantling soon had me on the brink of stating cam belt failure so off came the cover! Cam belt was (in places) half it's normal width and looking very sorry for itself!
Been back over today and took a Gates kit. Got it all stripped down, set the crank to TDC and both cams were miles off! A quick google and the new belt and tensioners were fitted all correctly aligned. Re-fitted the cover and then we spent half an hour trying to figure out how the aux belt went back on ;D ;D Thinking it had taken valves (being a 16v) we tentatively turned it over and it roared into life! A little top end rattly but that soon quietened down once the lifters re-filled. I left kevin just as it was getting too dark to work with it ticking over as sweet as a nut.
A nice afternoons work all in all and thank Mrs KevinM for the tea for me please Kevin :y
« Reply #6 on: 21 December 2010, 20:47:13 »
Well done W 8-) :y
It's great to get an up-date on problems. :y
Welung666
« Reply #7 on: 21 December 2010, 20:52:06 »
Well done W 8-) :y
Yes Z, it's not often a resolution gets posted so I thought I would for this one ;) I was, however, very surprised that there weren't any valves gone as I didn't think any of the 16v engines were non-contact! :y
kevinminton
« Reply #8 on: 21 December 2010, 21:12:50 »
(Just sat down after tidying up, running errands, packing bag for work trip tomorrow).
Thanks, Lee. Your diagnosis was spot on. Car now goes like snow off a shovel ...
Son has got his car back for Xmas, and no more Taxidad for me.
I will have no hesitation in recommending your work - a great job done enthusiastically in adverse weather.
You're welcome to the tea of course - we'll try to get some proper mince pies in next time.
Thanks again.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #9 on: 22 December 2010, 15:12:01 »
Glad you have your Son's car back on the road Kevin :y
