Author Topic: TC  (Read 4703 times)
Re: TC
« Reply #15 on: 21 December 2010, 21:17:23 »
I suspect that there are three different ABS types on Omega.
type 1 - introdces a misfire as the traction control method - truly agricultural.
type 2 - from mini-facelift, uses the brakes, too.
type 3 - not sure if from facelift or from DBW-on has the same ABS and TC, but also performs the front/rear split.
I reckon we one have 1 & 2....   :-/
2woody
  • Northumberland
Re: TC
« Reply #16 on: 22 December 2010, 23:13:57 »
it's a suspicion based on the dbw cars having a different master cylinder ( 25/25 instead of 25/20 ), which is what I'd expect for a car with EBD.
Re: TC
« Reply #17 on: 22 December 2010, 23:38:09 »
Electronic brakefource distribution. It was definitely coming from the pas side rear corner....
Re: TC
« Reply #18 on: 23 December 2010, 00:52:31 »
I wonder if they did it when they introduced ESP as an option?
There is wiring for a yaw sensor, etc. shown on the DBW diagrams. Never seen one with it fitted though.
Re: TC
« Reply #19 on: 23 December 2010, 00:54:37 »
So what constitutes ESP? Yaw sensor and relevant software? Can it be that simple?
Re: TC
« Reply #20 on: 23 December 2010, 01:05:17 »
Yaw sensor and steering angle sensor hooked up by CAN to the ABS/TC ECU, IIRC.
It can sense whether the car is following the course commanded by the driver and spoil the fun stop the crash. In theory.
2woody
  • Northumberland
Re: TC
« Reply #21 on: 23 December 2010, 18:55:45 »
you don't need a yaw-rate sensor for EBD - just a change in ABS block part number.
Re: TC
« Reply #22 on: 23 December 2010, 20:27:20 »
Kevin and Chris were talking about ESP, though (off your reference to EBD) :)
