Author Topic: Audi 3.0 V6 SE Avant Quattro - Do I buy?  (Read 2156 times)
smithpa7
« on: 29 December 2010, 21:24:11 »
Hello everyone. I need your advice on something not related to Omegas :o
I have the chance to purchase an Audi 3.0 V6 SE Avant Quattro. We are looking to replace the BMW 525i estate which is absolutely terrible in the snow and ice. It has spent the last 3 winters sitting on the drive.
The Audi is a 2002. With 106000 miles. A full service history and had the cambelts changed 30000 miles ago. The car is immaculate( Even the spare wheel has never been used). The car is £4500, I am sure I can reduce this by a few hundred :y :y :y
Are these any good in wintry weather and are they reliable?
Many Thanks
 :y :y :y
Re: Audi 3.0 V6 SE Avant Quattro - Do I buy?
« Reply #1 on: 29 December 2010, 21:27:01 »
As its 4wd I would imagine it would be better than most other comparable cars when the going gets slippery. :-/
Welung666
« Reply #2 on: 29 December 2010, 21:44:21 »
Although it's a 4x4 it'll only be as good as it's boots ;) Not a bad motor though :y
« Reply #3 on: 29 December 2010, 21:51:18 »
You may want something with greater ground clearance all the same.
Nice cars but like the Volvo XC70 I had the parts cost (and labour charge if applicable) will be substantial.
« Reply #4 on: 29 December 2010, 22:04:29 »
Quattro systems are brilliant in snow and ice, the Audi All Road (A6 Avant but with leccy air suspension) gives better ground clearance.
Looking at them ourselves as a replacement if these winters continue!
« Reply #5 on: 29 December 2010, 22:28:29 »
[/highlight]
Bugger! :( I was looking forward to buying a new 'cossie' & loads of factor 50 & fitting a sand filter to the miggy! >:( ;)
« Reply #6 on: 29 December 2010, 22:29:51 »
fact!!  if the boots are not suitable it doesnt matter  even if you use 8x8..  add the cost of winter tires..
by the way , they are good cars..
smithpa7
« Reply #7 on: 30 December 2010, 10:35:43 »
Cem, I have never heard of winter tyres ;D ;D ;D
Can you tell everyone about them :y :y
Thanks to everyone who replied. I am hoping to get home in time on Monday to test the car. I will let you know :) :)
« Last Edit: 30 December 2010, 10:36:07 by smithpa7 »
« Reply #8 on: 30 December 2010, 17:01:22 »
they are known as snow tires  ;D but thats wrong, they can be used also on dry and wet.. which they perform much better than the usual summer tires in cold weather where normal summer tires start to loose grip because of their wrong compounds for that weather :D :y
« Last Edit: 30 December 2010, 17:01:36 by cem_devecioglu »
tidla
  • solihull
« Reply #9 on: 30 December 2010, 17:38:58 »
huge 4x4 height matters not for road use.
does mean that the 3.0 power get transferred to the tarmac followed by a forward motion  rather than a tc light flashing at ya!
