Pages: 1 2 [3]  All   Go Down
Author Topic: That bloody Elite  (Read 6259 times)
Re: That bloody Elite
« Reply #30 on: 01 January 2011, 22:18:19 »
Hurts more than the Lag issue by some distance.  :(
Power lag/loss when converted to LPG?
The kits that chrisgixer and I use have a nasty intermittent lag at certain rpms under certain circumstances...
Minor power loss to be expected afaik. Occasional lag on some gear changes, and in my case lift off from Wot, should be possible to tune out, but we can't quite eradicate it on a tune up run, and it tends to leak back in over a period of a couple of months.
SMD
  • London
    • :( nowt
« Reply #31 on: 01 January 2011, 22:38:41 »
Did you get this issue when running on petrol too?
« Reply #32 on: 01 January 2011, 23:58:28 »
No, ran perfect on petrol.
.....although.....    My current 3.2 had a slight lift off issue on petrol.(it has no LPG fitted currently) I have since found water in the plug wells on 2,4,6 bank after a missfire episode. I must check if the lift off lag is still there having replaced the plugs and cleaned out the wells. Hmmmm, I wonder?
« Reply #33 on: 02 January 2011, 23:04:54 »
Had same problem with mine when I first bought it - large wooden fence pole worked for me TB  :y
Pages: 1 2 [3]  All   Go Up
