Author Topic: silicon sealants  (Read 2284 times)
silicon sealants
« on: 07 January 2011, 00:50:15 »
Been having problems with the oil pressure light flickering on her Smart.
I finally got a round to removing the sump pan today to have a look.
It looks like someone has used a sealant similar to Vx's black by the bucket load. Trouble is, some of it found its way into the oil pick-up tube.
and this lump too
which is probably why the filter was collapsing  under the pump's suction. This has only ben in the car for around 3000 miles.
Hence my previous question re cure times for the grey sealant  ;)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: silicon sealants
« Reply #1 on: 07 January 2011, 07:19:18 »
not nice, seen worse when people used to put saw dust in engine T***s.,, have you got all of it out andy???
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 07 January 2011, 08:36:44 »
I would of thought the filter was collapsing due to being clogged up.
Filter should be on the pressurised side (that way they can use a finer grade filter medium and give much better filtering and is the standard approach) so should not be affected by a blocked pickup.
« Reply #3 on: 07 January 2011, 09:44:35 »
The oil & filter had only been in for a couple or 3 thousand miles, and the rest of the isides looks fairly clean, no buid up of crud.
You could very well be right, I'll have another look as I build it up today - it's trying to bl00dy snow though  :o - but the pick-up tube does look to be more or less opposite the filter housing  :-/ :-/
Anyway, a load of silcon on the strainer isn't going to help oil pressure  :y
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #4 on: 07 January 2011, 11:28:46 »
Better there than clogging an oilway! Looks like the strainer was doing its job.  :y
« Reply #5 on: 07 January 2011, 11:49:57 »
Correct!  :y  :y  :y
« Reply #6 on: 08 January 2011, 01:09:31 »
So is the sealant from the factory or some numpty mechanic? any history?
« Reply #7 on: 08 January 2011, 09:37:13 »
It's not from factory as you can see marks on the sealing face of the steel sump where a medium sized screwdriver has been drifted in to remove it some time previous. Fortunately the ally block seems to have survived unscathed. You'd think a garage would have had a nice broad flat scraper/chisel like mine to remove it.  ;)
« Reply #8 on: 08 January 2011, 09:41:53 »
They probably have but it might not have been within the mechanics reach and would have meant him moving to get it ::) ;D
« Last Edit: 08 January 2011, 09:55:37 by Elite_Pete »
« Reply #9 on: 08 January 2011, 09:43:44 »
They probably have but it might not have been with the mechanice reach and would have meant him moving to get it ::) ;D
Probably more like it  ;D. But if you could see the state of my garage it's a wonder I knew where mine was.  ::)
« Last Edit: 08 January 2011, 09:44:10 by Andy_B »
« Reply #10 on: 08 January 2011, 13:10:06 »
No surprise that the oil pressure light flickering at idle when warm is now sorted.  :y And although not perfect, it sounds a lot quieter around the cam chain, the tensioner is hydraulic so is now presumably get enough oil to do its job.  :y :y
hercules
  • sunnyudders
« Reply #11 on: 08 January 2011, 15:53:24 »
i had that prob with a cav i bought years ago the 2nd day i had it went for a run down the motorway and light came on then rattle rattle rattle,dropped sump cleaned pipe back together with cheap oil but no good,rang dealer and on my paperwork sold as seen the barsteward but i managed to get him to cover the cost of a new cambelt and gaskets when i replaced engine with a scrapper one.looking back now older and wiser i would of gone for it more to get my money back and old car but its under the bridge now
