Author Topic: Maintenance Guides  (Read 4605 times)
Julian
Maintenance Guides
« on: 08 January 2011, 14:00:08 »
Hello,
 I do not want to be negative about these guides as I have had to use just about every one and have been impressed by some of the photos of hard to see bits. The advice about camber is incorrect if you do the maths and I have standard wheels the measurements will give near to 2 degrees. The cleaning of diesel injectors states that the copper washers should be replaced, BMW do not list them as a part, a diesel engine specialist did not have any even in the odd washers draw, and he has never changed them saying that you just clean the seating areas bit of copper slip and do them up tight. There is no torque settings, no explanation of cleaning out the area around or in the injector thread area. The idea of using two spanners to split the body of the injector and standing on them, bad idea. I do not want to be negative as I said earlier but some of the advice can get you into trouble.
hotel21
  • The Kingdom of Fife
Re: Maintenance Guides
« Reply #1 on: 08 January 2011, 14:12:34 »
Hi Julian and thanks for the feedback.
I would refer you to the section in red at the start of the guides, and in particular:-
Obviously safety is paramount. These guides are all written by members who have done the jobs themselves, none of whom are professional technical authors. Therfore, they are to be read on the merit of items that will assist you rather than a precise 'follow this to the letter' type guide.
Whilst every care is taken to ensure the accuracy of these guides, you should satisfy yourself that they are applicable to your vehicle, you have the necessary skills to carry out the task and that you follow the usual safety procedures associated with working on any car.........
None of these guides are endorsed by the owners or administrators of this forum. You follow any of these guides at your own risk.
Will move your post to the general car chat section as its really not something suitable for the test area.   :y
« Reply #2 on: 08 January 2011, 14:32:57 »
having never had to split an injector I've had to go & find out where/when/why a foot was used. Having now found it ...... what's wrong with that? Not everyone has use of a big vice on a solid bench to hold the injector in so you can swing off it with a big breaker. This is also the kind of thing we'd all do at work when out in production areas otherwise we'd spend longer walking to & from workshops with spanners than we would on the job. Common sense has to be used though otherwise you end up fubar'ing stuff.  ;) ;) :y :y
Debs.
« Reply #3 on: 08 January 2011, 16:43:29 »
Hiya Julian,
My local motor factors has drawers full of various dia/bore soft copper washers (some 'rolled' with a refractory-fibre filling).
Old-fashioned auto. shops often have that kind of useful hard-to-source stuff.
Personally, I have found the OOF maintenance guides to be very helpful; although sometimes I have to read them a few times first and then again as I`m doing the work if it`s a job that I`m not confident tackling for the first time......and also, sometimes I`ll ask members for clarification via one the the forum sections.:y
Do join in and contribute; perhaps you might like to help update the maintenance guide, if there are areas you think need clarification in depth of detail. ;)
« Reply #4 on: 10 January 2011, 19:55:51 »
Hello,
This is concerning, please could you explain in more detail. Which guide? And what procedure? Thanks.
Boditza
  • Craiova, Romania
« Reply #5 on: 11 January 2011, 07:16:02 »
they are made by members, and they are not official guides from specialists (most of them :P). The only thing wrong with the guides is that there aren't pictures, not enough in some cases. for example the guide in changing the steering column has no pics just words. for international users its relativly hard to understand, but a pic makes more than 1000 words :P. On the door card removal the guide is complete just it does not say how to practicly remove it from the door because its a little stuck on the upper side at the glass. i removed all the screws, sockets from el win, puddle but couldn't get it off because i was afraid not to brake something :'(
« Reply #6 on: 11 January 2011, 20:49:12 »
Please feel free to add an suggestions/modifications to any of the guides. Either post in test, or PM Jimbob
« Reply #7 on: 11 January 2011, 21:06:45 »
Beware of who ever gave that poor advice on injector O rings.
The pressures they are exposed to are very high and with time, the copper goes hard and will not give a reliable seal.
You can get the washers pretty easily and they should be replaced, the absolute least you should do is re anneal the old ones before fitting.
And copper slip will not do a thing to aid sealing.  :y :y
« Reply #8 on: 11 January 2011, 21:15:27 »
Cant see anything wrong with the camber guide either
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #9 on: 11 January 2011, 21:19:48 »
At least people take the time to try and help other people, which is nice.
TC and BnQ Trade holder.
« Reply #10 on: 11 January 2011, 21:37:00 »
 :-X.     Although it has it's uses,  I am intrigued where this stuff gets it's magical healing powers. Maybe I should have  applied it liberally to those blasted Falkens.    :D
« Reply #11 on: 11 January 2011, 21:43:39 »
....was assuming it was miss read tbh, but thanks Mark.
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #12 on: 13 January 2011, 13:11:39 »
an old mechanic once told me that by holding a copper washer over a flame for a few seconds helps the re- bedding in situ. as for Hoofing its guide , i personally would follow his guidance to the letter, he, :ys a very knowledgeable guy.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #13 on: 13 January 2011, 17:29:51 »
Doesn't look like he's coming back after lobbing in those two firecrackers. ;D ;D ;D
« Reply #14 on: 14 January 2011, 08:56:45 »
Given his postcount, and the fact he has used the guides, I'm guessing Julian is more of a lurker than an active member. Which is fine :)
I'm sure all the guides could be improved in some way, so I think he is right to make such queries/suggestions to see if we can improve them.
I think the copper washers have been covered before - I certainly struggled to get them from a Bosch Diesel 'specialist', who claimed not to sell them, so I annealed mine.  A few of us have looked over the camber thing, none of us can see anything obvious - Julian, if you are reading, can you clarify what part you think needs extra clarity/modification?
