Author Topic: LPG Opinion  (Read 5151 times)
Re: LPG Opinion
« Reply #15 on: 14 January 2011, 22:18:18 »
Firstly, that seems too cheap.
Secondly, to do it in a day they almost certainly won't be removing the inlet manifold to drill it :o
Thirdly, how do they justify charging more for a cylinder tank... They're considerably cheaper than toroidal tanks! Oh... And if fitting a cylinder, 80L is better suited and takes similar space to a 70.
Fourth, as above posts really... As far as DIY goes, if you can service it and clean the breathers then you can almost certainly fit LPG. It's not particularly hard, especially if you follow the guides ;)
although fitting is not that hard, the problem starts when calibrating/tuning the system.. and thats ona car without any issues :-/
The Stag kit that many of us have is actually very easy to do, especially if you follow the excellent guide Kevin composed for that part :y
Stag Kit ok.. Prince , BRC  :-/  most of those firms keep the parameters to themselves only >:(
Prins simply will not supply to DIY installers in the UK, approved installers only. Unless you know an installer well enough  ;) still 50% more expensive than stag.
Re: LPG Opinion
« Reply #16 on: 14 January 2011, 22:21:48 »
that solves the problem.. :y
Ken T
  • Stockport
Re: LPG Opinion
« Reply #17 on: 14 January 2011, 22:36:41 »
Yes, watch kits like OMVL, Bigas etc, they have limited software available for tuning. It works OK'ish, but you can't change parameters like time to change over, or get at the actual fuel map, without a dongle which is another £50. It does work, but its hard to fine tune it.
Ken
markspark
  • Bolton
Re: LPG Opinion
« Reply #18 on: 15 January 2011, 00:12:17 »
on a 3.2 if you register lpg conversion with dvla is the road tax cheeper aswell
Re: LPG Opinion
« Reply #19 on: 15 January 2011, 00:30:56 »
Last year it was cheaper by £10  :(
Re: LPG Opinion
« Reply #20 on: 15 January 2011, 00:32:41 »
I received this email recently, not enquired for some months, so must be looking for work.......
Dear Mike
Thank you for your enquiry to convert your Vauxhall Omega  to environmentally friendly LPG that is 50% cheaper than petrol. As part of our opening offer this conversion can be made for the unbeatable price of £799.00 + VAT for this four cylinder vehicle, using Lovato multipoint sequential injection systems,  and this quote includes:
- 2 yrs parts and labour warranty
- Free 1000 miles service
- Largest suitable tank in the boot area
- LPGA certification
- Conversion within 3 days subject to availability of kit.
Please feel free to contact me on the number below if you have any further queries, or to book your vehicle in for conversion.
Kind regards
Re: LPG Opinion
« Reply #21 on: 15 January 2011, 00:49:16 »
Lovato is an Italian make and quite good. But, as I found out when I had it on my Rangie, parts availability and local support can be an issue ;)
« Last Edit: 15 January 2011, 10:53:31 by Lazydocker »
Re: LPG Opinion
« Reply #22 on: 15 January 2011, 01:03:09 »
Locate is an Italian make and quite good. But, as I found out when I had it on my Rangie, parts availability and local support can be an issue ;)
Local depot assuming this is in response to an enquiry I made some time ago.....
Recent changes in fuel prices question the benefit of conversion... :-/
Unexpected recent car costs put on hold any plans anyway....  ::) ::)
Re: LPG Opinion
« Reply #23 on: 15 January 2011, 10:47:09 »
a 52L tank in the spare wheel well gives you about 260 miles motorway driving, with the gauge reading about 30MPG. Its handy giving you the whole boot space, but is a bit restrictive in range.
Its not that hard to DIY, my spare 2.2 inlet manifold is about somewhere(tunnie's ?) so you can get it drilled and nozzles fitted before you start, which means the car is only out of use for the time it takes to swap the manifold. The rest of the install can be done in easy sections.
Ken
Sometimes I jealous of 2.2s., that kind of range from such a small tank...
...don't worry, the jealousy completely disappears as soon as I leave the fuel station ;D
Re: LPG Opinion
« Reply #24 on: 15 January 2011, 11:03:30 »
Ken
It comes right back when you have to pull in again, where as i can easily do another 150 miles  :P
Re: LPG Opinion
« Reply #25 on: 15 January 2011, 12:29:32 »
Ken
But who has the bigger smile on their face :D
Re: LPG Opinion
« Reply #26 on: 15 January 2011, 12:30:34 »
Ken
Me, giving two fingers to the fat man filling up  ;D
scalli
Re: LPG Opinion
« Reply #27 on: 15 January 2011, 12:30:56 »
Go and find out what kit they are fitting and if single point or sequential multi point and let me know. I suspect at that price it will be single point with a vaporiser on the induction side rather than individual injectors in the manifold. Nothing wrong with single point, just a slight drop in mpg from my experience. To give you an idea our van does 18mpg round town on petrol but 16mpg on gas, of course the cheaper fuel offsets that easily and the price difference on our van was £1000 for the single point and £1800 for the sequential multi point.
Ours was fitted by these guys, http://www.ozonlpg.com/ bit far out but they are highly recommended
If you are going to DIY buy the Iwema http://www.iwemalpg.com/, best bit of DIY kit in my experience and comes with a certificate to show the insurers if needed (though in all the years I have used multi fuel vehicles I have never been asked once).
cube
  • Leeds
Re: LPG Opinion
« Reply #28 on: 15 January 2011, 12:36:48 »
Fit it myself Scalli !! :P  :o :o :o
You know i burn water !!!
lol lol lol
2.2 petrol GLS estate
Re: LPG Opinion
« Reply #29 on: 15 January 2011, 12:53:57 »
yes.. here their parts can be found in big cities easily .. price range similiar to BRC..
« Last Edit: 15 January 2011, 12:54:31 by cem_devecioglu »
Page created in 0.023 seconds with 20 queries.
