Author Topic: solving my slightly rusty wheel arch this weeknd..  (Read 3195 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 27 January 2011, 17:36:06 »
..... would anyone be interested to see before and after photos? i was thinking of photographing the whole process including removing the rust, filling the 'wounded' area and respraying. :)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: solving my slightly rusty wheel arch this weeknd..
« Reply #1 on: 27 January 2011, 17:53:36 »
..... also im buying the filler friday... whats the best to use?
RIP Paul Lovejoy
jads
  • birmingham
« Reply #2 on: 27 January 2011, 18:01:53 »
yes would be very intrested to see some pic's as i need to
do the bottom of one of my back doors but was going to wait till weather is a lot warmer :y
Webby the Bear
  • Northampton
« Reply #3 on: 27 January 2011, 18:17:34 »
ok mate ill photograph the whole thing :):):)
the way im gonna do it is as follows:
1. sanding the area down as much as i can (its actually really hard to sand down to the metal)
2. treating the area with liquid rust remover (when i did it before it took a few coats of this stuff to remove all traces of rust!)
3. once dry, fill in the area. ive never used this so am unsure whether ill need to sand after application or not???
4. couple of coats of grey primer
5. couple of coats of the colour (mines star silver II)
RIP Paul Lovejoy
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« Reply #4 on: 27 January 2011, 18:36:57 »
6. A couple of coats of Lacquer once the colour has set  ;)
That will make it shine  :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
Webby the Bear
  • Northampton
« Reply #5 on: 27 January 2011, 18:50:19 »
lol yeah i got that... just forgot to say :)
RIP Paul Lovejoy
markfree
« Reply #6 on: 27 January 2011, 19:24:50 »
7. repeat steps 1 thru 6 in 6 months time when the rust re-appears.
Webby the Bear
  • Northampton
« Reply #7 on: 27 January 2011, 19:39:47 »
lol yeah thats a good point.... i only did it back in the summer!!!  :'( :'( :'(
RIP Paul Lovejoy
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 27 January 2011, 22:29:18 »
you need to take a grinder to the rust and get rid of it completely to make it last,means more filler work though
other rides
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #9 on: 27 January 2011, 23:42:40 »
i'll second that that rust has to be gone gone gone! grinding is the only way to go and then give it some anti rust i don't know how bad it is but you can always rivet (or weld if you have the facilities) new metal in tap it back and then start with the filler, don't forget to knock back your filler/primer after application and between the top coat and laqueur wet and dry 2000 grit and with the final laquer  you can mud it ( a harder cutting compound) or t-cut and plenty of elbow grease to really make it shine, i would suggest a light top coat and then the final top coat and the laquer as it stops the runs! the biggest downfall of home sparaying is the spray fall and the base not being clean enough.
« Last Edit: 27 January 2011, 23:44:24 by mrgreen »
Warning: Dates in Calendar are closer than they appear.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #10 on: 28 January 2011, 00:16:29 »
to do a lasting de-rust I use a gritblaster gun works with compressed air,lot's of it
Webby the Bear
  • Northampton
« Reply #11 on: 28 January 2011, 00:45:58 »
the most industrial sander i have is my black and decker mouse :)
seriously though i have a metal file which worked well last time. ill try that again. bit more elbow grease tho ;)
RIP Paul Lovejoy
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #12 on: 28 January 2011, 12:40:58 »
As per lanky Edd China on Wheeler Dealers, apply the filler in thin layers, then sand back, repeat as necessary until you have the desired finish/profile.  :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #13 on: 28 January 2011, 13:12:01 »
Hey ups Webby, If it hasn't re appeared in six months then come over and do mine. I'll pick you up at Malaga airport in the morning and drop you back there in the evening. :y :y
