8inch Touchscreen Installing
Started by Craig_R, 07 July 2007, 14:48:39
Taxi_Driver
Actually its been helping me cut down.....coz when where busy like this afternoon/evening.....you dont have time to stop.....so cuts the smoking down  :y
Craig_R
I would do Dave But its alittle knacked ill have to have a look to see why its jammed open at the mo. It might of just jumped off a cog or some thing and the front is off at the mo I unclipped it from the ashtray unit to use as a stencil  :-? to draw around to get the shape right  ::)
Craig
Mod's
[To be Fitted]Reverse Sensors
Taxi_Driver
QuoteI would do Dave But its alittle knacked ill have to have a look to see why its jammed open at the mo. It might of just jumped off a cog or some thing and the front is off at the mo I unclipped it from the ashtray unit to use as a stencil  :-? to draw around to get the shape right  ::)
Craig
Hmmm mines a cog out too.....Mr Mark had a go at it at the lakes......and ive used just about all the force i can without breaking it....but will it line up ok......no  :(
Dont worry then.
spookyman60
#18
thats a pro install ive just completed a full install on my car and well it dont look at all as good as yours as well includeing 8 inch touchscreen although mine is a prefacelift and u cant really mounth the screen as if its stock althought i have found some good frontend software like centrafuse http://www.fluxmedia.net/ thats what im useing atm in my system and its running on a micro atx with a m2-atx powersupply with an AMD Sempron 2800+ and a gig of ram bolted down ofc and the screen has to sit infront of the two middle vents some usful links if u get around to build a pro pc to go in the car
http://www.linitx.com/ they sell all the pc side as well as touch screen but i sourced mine from ebay for 112 quid and
http://www.digitalcar.co.uk/ they will help with all the niggles u have with it
i wish i had a facelift now with a double din
keep up the work and keep us informed
M2-ATX - 160W Intelligent Car PSU £58.46
http://cgi.ebay.co.uk/GPS-Receiver-Sat-Nav-Laptop-PPC-PDA-USB-Car-Yacht-DIY_W0QQitemZ300125662657QQihZ020QQcategoryZ75327QQrdZ1QQcmdZViewItem#ebayphotohosting thats the gps reciever 19 quid no matter where i go whether it be peak district i always get over 8 satalites and the antena is sat in my rear screen
screen £112
and then about £20 on fuse holders and misc the amp i already had a 4 channel amp and it came in really handy
so 200 quid on my install as i already had most of it lieing around the only problem i can see is the hard drive failing as its not a laptop sata :( on mine but you wont have that problem hope ive helped u with links and everything
