Skover project
Started by venom, 11 January 2011, 19:41:15
venom
#15
Errrmmm F*****G NO or the poxy screw on body kit :-[ or the bumpers  :y
Ken
Hannah Judes Dad
The bumpers look like they belong on a Saab 99  :)
Welung666
I'm almost ashamed that was attached to my A Frame ;) ;D ;D
This may not end up a Skover either from the conversation Venom and I had... It may end up as a Skauxhall ;D ;D
QuoteI'm almost ashamed that was attached to my A Frame ;) ;D ;D
Easy does it! Don't want too much weight overhanging that rear axle or it'll be a bit of a Skoditchfinder. :o
venom
I'm afraid it will be a Skover as the transaxle wont take the torque of the Vauxhall lump  :(
Ken
Welung666
AR$E :(
tidla
are these the skodas that (forgot the tech term) carry the weight on the driveshafts with the difficult to remove rear drums?
venom
Well did a small bit today, took off the poxy body kit, front and rear bumpers & rear panel in readiness for the engine removal over the weekend.
Ken
venom
If it was only this easy to get to the front of the Omega's engine for the cam belt  ;D
Ken
r1
as its the 136 it has the later engine that went into the new skodas.
looks someone has tried to make it go faster with that carb on it.
years ago i used to race a 130 skoda good fun cars.
good luck with the project
venom
Quoteas its the 136 it has the later engine that went into the new skodas.
Cheers r1 what sort of racing ?
Ken
r1
it was auto grass racing had a few wins against mk1/mk2/escorts  as they where good off the line with the engine over the drive wheels.
venom
I've looked at the flywheels.
The Rover flywheel (Left) is a similar size, but uses a 200mm friction plate and the Skoda is a 190mm plus the ring gear is in the wrong place. So I looked at mounting the Skoda flywheel to the crank. Apart from more mounting bolts, the centre bore is 35mm for Skoda and 34mm on Rover.
So to get the flywheel sat central, I got a brass sleeve made, pressed in and had it turned out to 34mm
This allowed me to make up a 34mm mandrel and bolt the 2 flywheels concentrically back to back and have look at the mounting bolts.
2 holes nearly line up, and the 5 remaining (4 bolts and 1 dowel hole) can be drilled into the Skoda flywheel. The 2 that nearly line up will be slotted the 3mm so I now have the required 7 holes for the Rover crank  :y
Ken
venom
Well did quite good today and got the interior striped out and so far can only find a quite a big bit to weld up
And this is it but looks like some time ago it's had a bit done here before
And here
Without poking around to much the rest seems solid enough.
Looks like the rear screen rubber needs replacing as it's leaking.
Ken
