Author Topic: V6 LPG Kit Prices  (Read 1927 times)
V6 LPG Kit Prices
« on: 07 February 2011, 19:37:19 »
[size=18]PLEASE DO NOT COMMENT ON THIS THREAD[/size][/b]
It is for information only. Perhaps an Admin could lock it?
Right... It's  been longer than planned but I have managed to sort a kit and price from the supplier. To confirm, this has taken a little while for a couple of reasons. The main one being that I have specified some specific items which are not normally supplied. The second one being an IT issue.
I'm not going to publish the exact price as this price is specifically for members of OOF (price available on PM, along with contact details) but will give you a guide...
V6 Kit Contents
Stag 300 Plus ECU
Diagnostic software
If you don't have the Stag diagnostic lead, you need to buy one, or borrow from a local member!
Injectors
Vapour Filter
Full front end pipework, some metal strip for mounting items etc
7 metres of Polyflex pipe (much easier to work with than copper!) and ends
Pipe Clips and various sundries etc...
2x90 degree 16mm water connections
Reducer to be specified, OMVL or our twin if available
Delivery is £15
The Stag 300 Premium kit is available, which has some CANBUS compatibilities and will automatically adjust LPG trims to match petrol trim changes. AFAIK, this function would not actually be much benefit on the Omega ;) This will be an additional £40+VAT on top of the standard kit price.
The Front End Kit above is a comprehensive kit and contains everything needed to fit LPG excluding the tank and frame and filler. The supplier is happy to quote on an individual basis for tanks, but he does not hold them in stock so will be "drop shipped" from his supplier.  The recommendation is for a 4 hole tank due to the high fuel demand of a V6 at "Full Chat", although there may be some High Flow Multivalves suitable available soon... Talk to the supplier
The price for the kit listed above? As I said... You'll have to PM me to ensure that only OOF members are benefiting from this deal ;) But I can assure you it is worthwhile and will say that it is less than any other supplier is charging for a more basic kit :y :y I will state that it is less than £350+VAT as I was originally expecting and works out cheaper than I paid for mine a couple of years ago :y :y
« Last Edit: 09 March 2011, 19:04:10 by TheBoy »
