Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Daytime running lights  (Read 13764 times)
Re: Daytime running lights
« Reply #30 on: 21 February 2011, 22:52:59 »
Dont have a problem with them personally. But some Mercs have them brighter than omega hids afaict! Seems excessive.
They might sit well in the slots of an irmscher bumper though....    ::).   ;)
« Reply #31 on: 21 February 2011, 22:57:17 »
Just below the fog lights in the slot undernieth. Not exactly high on the list though... :D
Nickbat
« Reply #32 on: 21 February 2011, 22:57:48 »
I see this chap on the Vectra forum was stopped by the police last September for having retrofitted DRLs
http://www.vectra-c.com/forum/showthread.php?p=1321000
And yet, this DfT document says you can fit DRLs, provided they are made-for-piurpose and carry the necessary European certification stamp.
http://www.dft.gov.uk/pgr/roads/vehicles/vssafety/info-runninglights.pdf
Once again a case of legislation which few have heard of and even the police are not sure of.  ::) ::)
Agemo
  • Cleethorpes
  • Insignia
« Reply #33 on: 21 February 2011, 23:15:10 »
Most wagons coming from Scandinavian countries have had them for years, (all Scanias do) but just have a fuse pulled for UK use.
I wonder if Migs are the same  ::)
« Last Edit: 21 February 2011, 23:16:29 by Agemo »
Martin_1962
« Reply #34 on: 21 February 2011, 23:19:57 »
I think they are terrible things, they waste electricity, make some cars look like nobs - Mercedes, and they dazzle like nobodies business.
I also hate the pulsing rear LED lights, they give me a headache, the cure is to follow on full beam so you over power them.
Some dog eating country ones are terrible as is a small open top Peugeot.
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #35 on: 22 February 2011, 11:31:25 »
I don't understand why there should be a need for DRL's in this country. :-/ If the light isn't very good just switch your normal lights on. Stone me, if you can't see a car in normal daylight you shouldn't be driving! ::)
« Reply #36 on: 22 February 2011, 11:34:45 »
Nanny state Bob, so many dont turn them on and hence make the car do it automaticaly will make it safer.
Slightly suprised about the dazzling though which does suggest a legislation issue as the light output has to be quite low.
I guess its the LED's that cause the issue with the very narrow beam angle they emit light out at.
mkirky
  • Cheshire
« Reply #37 on: 22 February 2011, 11:40:35 »
With the Goverments cut backs hopefullythey will GO ;D
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
« Reply #38 on: 22 February 2011, 11:59:32 »
I would like to nominate this for post of the year!
It may also be an epileptic thing, IIRC there was something about LED cat's eyes recently. If you drive past them too quick (legally too), because of the tight beam angle, they can appear to be strobing & cause issues that way
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
« Reply #39 on: 22 February 2011, 13:39:02 »
That's because they are strobing. They are pulse-width modulated to give constant output despite a variable battery voltage. ;)
Same with the LED tail lights on cars. They are dimmed from brake light intensity by PWM in'g them so if they move across your field of vision rapidly, you get a similar light trail. I think this is probably what Martin was objecting to. I must say, I find it irritating, too.
Lampynoiseboy
  • SE Essex
« Reply #40 on: 22 February 2011, 13:42:17 »
Very true, however the effect is much more noticeable when driving past them, than staring straight at them, think it's a combination of PWN & tight beam?
Can't think they'd be debating banning ONLY cat's eyes led's not rear lights if that was the case?
Martin_1962
« Reply #41 on: 22 February 2011, 14:22:53 »
It is and I go full beam & fog lights and that minimises the effect. >:( >:(
« Reply #42 on: 22 February 2011, 14:38:23 »
I think it's because they are moving rapidly through your field of vision at that point, which "freezes" the flashing of the lights. Plus, your eyesight is more sensitive to changes/ movement at the extremes of your field of vision anyway.
I can see how they might be distracting
Agreed. Rear lights are only an issue as your vision scans past them, but I believe it's the same principle.
So now both you and the car in front are having difficulty seeing? ;)
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #43 on: 22 February 2011, 14:45:46 »
Likewise I cant for the life of me see the point,with the exception of the motor bike how can you not see all motors in daylight? and audis to me simply look dilly or some may say gay and often promote a chuckle in miggy's driving seat.For now I won't go on about BM's "Angel Eyes" now I ask you,for me more like "goofy eyes" Seriously I think on our heavy trafficked roads the motorcyclist will really lose out big time,just be another light lost among many
« Reply #44 on: 22 February 2011, 14:48:26 »
I'll wait for the thread about someone slamming on the brakes in front of you then ;) ;)
Pages: 1 2 [3] 4 5 6   Go Up
