Author Topic: 2 different alloys on one car  (Read 5487 times)
Danny
  • Wigan, Greater Manchester
« on: 24 February 2011, 19:09:49 »
quite a radical idea and probably not to anyone else's taste but if i keep my omega i'm toying with the idea of taking the 6 spoke MV6 alloys off just one side of my car and replacing them with elite flat face alloys, because i like both styles, and you can only ever see one side of the car at any one time!
am i likely to experience any problems at all?
Re: 2 different alloys on one car
« Reply #1 on: 24 February 2011, 19:13:15 »
As long as the size, profile, ratio, speed rating etc is the same on each axle, then you'll be ok from a legal / technical perspective.
« Reply #2 on: 24 February 2011, 19:15:39 »
They are both 17", so as long as the same tyres are on all 4, should be fine, may look a bit odd though!
Danny
« Reply #3 on: 24 February 2011, 19:16:56 »
well it wont though, cos you wont ever see both styles at the same time!
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #4 on: 24 February 2011, 19:22:58 »
Budget tyres, false economy.
« Reply #5 on: 24 February 2011, 19:25:08 »
But you could see in a car park for example, anyway you can have as long as the tyres are the same on each axle it's not a problem  :y
Bent valve
« Reply #6 on: 24 February 2011, 20:01:13 »
Theyr'e sure to be a different weight from each other which could lead to the car pulling to one side, and in the event of an accident for whatever reason your insurance company would take a dim view, and if you decided to tell them beforehand they would probably refuse to insure you ::)
tidla
  • solihull
« Reply #7 on: 24 February 2011, 23:54:04 »
just seen this on "odd one in" so cannot claim it.
 ;D
that idea would be "terry  bull"
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 25 February 2011, 10:44:56 »
I would agree with Bent valve here.
Even a small difference in alloy weight will have significant impact on the handling.
Remembere that the wheels spin rather fast and the forces produced by different mass of alloys can be big, and will grow with speed increase.
mkirky
  • Cheshire
« Reply #9 on: 25 February 2011, 10:50:04 »
I agree  two different rolling mass weights on the same axel will cause various problems
« Reply #10 on: 25 February 2011, 10:57:53 »
I keep reading this thread and getting a great vision!
Why not go the full hog in having two different styles of alloys and fit small ones at the front and huge ones on the rear?  A Omega Hot Rod is created !!! :y :y :y although perhaps the engine will need to be uprated!! ::) ::) ;D ;D ;D ;D ;D ;)
« Last Edit: 25 February 2011, 10:58:31 by Lizzie_Zoom »
Danny
« Reply #11 on: 25 February 2011, 14:01:02 »
i had in the back of my mind that the different alloys would possibly be different weights, which if true, means i just wouldn't do it
the idea came from a mazda RX7 we had at Japan North 2007. it had a chrome deep dish alloy on the rear on one side and a standard dish on the front, and on the other side it had black alloys, deep dish on the rear and standard at the front. it was only when i looked at the photos that i noticed it!
sport
  • Stoke on Trent
« Reply #12 on: 25 February 2011, 23:36:03 »
Hi i have two differant wheels on the front than the rear.
« Reply #13 on: 25 February 2011, 23:54:39 »
yep.. :y
omegabsw
  • Essex
« Reply #14 on: 27 February 2011, 13:00:32 »
No one has mentioned that the offset my be different therefore giving the car a wider track on one side only.
My Flat faced elite 17's are ET39 where as my Irmscher MV6 wheels are ET33. In real life you are not going to notice 6mm tho
