Author Topic: Engine mods, looking for opinions :)  (Read 4928 times)
Re: Engine mods, looking for opinions :)
« Reply #15 on: 22 February 2011, 22:12:26 »
Hmmm... V6 chip ::) ::) ::) That reminds me :-X :-X ::) ::)
Ah fak. Have you got a spare ECU?
Errm... Nope ::) Didn't think I needed one :-[
I dont have any spare chips, and its nice to keep your original in tack in case of issues.
Isn't the immobiliser linked to the ECU too? Just so I know what I need to get
We'll use your original ECU. We'll just use the chip from the scrap ECU ;)
« Reply #16 on: 22 February 2011, 22:14:54 »
Ahh OK... I wonder if anyone coming to Farnborough has one kicking around ::)
« Last Edit: 22 February 2011, 22:15:13 by Lazydocker »
« Reply #17 on: 22 February 2011, 22:20:08 »
Do you know what chip they take? 27256 IIRC?
I'll have a rummage in the junk box room house. :y
« Reply #18 on: 22 February 2011, 22:24:16 »
Have posted a wanted but only if it can be taken to the meet... Not expecting much luck TBH so if you do find one that'll be great :y
I suppose I could nip into somewhere and pick one up if we know exactly what we need?
« Reply #19 on: 23 February 2011, 09:34:36 »
I checked and I have a shedload of EPROMs of various sizes so will almost certainly have one. If someone can confirm the type I'll give it 15 minutes under the UV lamp to top up its' tan make sure it's erased. :y
« Reply #20 on: 23 February 2011, 09:38:29 »
Ahh... Marvellous :y :y TB would be the one to confirm, IIRC he's got one in his glovebox ;) ;)
Rogusu
« Reply #21 on: 23 February 2011, 12:48:56 »
Wow, thanks for all replies :)
I do not understand much the late ECU discussion, so I assume it is not related to my post, right? :)
So from what I have understood now is that the biggest gain will be from ECU chip. Some other can be from 3.2 intake manifold and exhaust manifold. Minor changes can be achieved by throttle porting and using better panel filter (I bought the car with Steinmetz panel filter, I assume this is good enaugh) and Mantzel type rezonator is not good for everyday use (but this I will probably try as it will cost me nothing :) So I will report back).
I would like to ask what is th heads porting? And what will the lighter flywheel do (from TheBoy´s post)? I cannot translate it :)
I would also like to ask if there are more types of throttle bodies. I am thinking about buying the top of 3.2 engine (from intake manifold up), prepare everything and then change it as one set...
You want performance, drop a V8 in....
Well, it is my dream :) To put supercharger there. Or V8. Or supercharged V8  8-) But unfortunately, I live in diesel country (1.9 Tdi is almost saint here, dont know why), so nice V8 is very expensive. I have almost bought 5.7 V8, but then I realised that I do not have experience, skill and equipement to complete such project. But it is still dream, so if anyone has some tips, how to, parts needed etc, I will be gratefull for anything, so I can make notes and maybe sometime in future... :)
Julian James
  • Birmingham
« Reply #22 on: 23 February 2011, 13:23:55 »
The Boy said it does "sod all"...
which means it does nothing!
(Where are you from?  What language?)
My personal understanding with lightweight flywheels is that they are quicker to speed up (less mass to rotate) that regular flywheels.  This should lead to increased acceleration.  However, they are also quicker to decelerate, and leave your car with less momentum, which is not a good thing if you live in an area with lots of hills!
Having said that, I have never installed a lightweight flywheel on ANY car, let alone an Omega.  And I'm certainly not as experienced on these cars as forum legends such as The Boy, and other people with 63 stars under their name!!! :P
Also I believe because the Omega has a different flywheel to normal, you would have to change the clutch too to match it.  Prob quite useful if you're going to go anywhere above 30% of the original BHP.
From what I've read about tuning Omegas, good things to do are:
Fit fast road cams (not race cams, unless it's just a track car!)
Uprated clutch - depends how much you push it...
Remap ECU?
(Of course some things have knock-on effects, like needing more fuel = bigger injectors = different FPR = uprated fuel pump! etc)  This is why most tuning is done in "stages", so things are upgraded simultaneously to complement each other.
The age old thing my friend say:  Air in, Air out.  This is a good place to start Mods, so Stainless Steel Exhaust etc.  Probably more important than most of the other stuff I've mentioned!
It all depends what you want to get out of it!!!  Most SERIOUS upgrades are probably over the top for a daily driver!!
One more thing though, is you can always loose weight!  I've been told the Omega weighs around 1700 kg.  So you can strip things you don't need, and even replace with lightweight (carbon fibre etc)  but I think we're getting beyond the realm of what you're asking!!  That's more for track cars and underground street racing!!!!
I hope some of this has helped, even if I have gone off on a bit of a Fast and Furious tangent!! :)
« Reply #23 on: 23 February 2011, 13:53:55 »
This all assumes the OP has a manual gearbox, of course!
But yes, a lightened flywheel will make a little difference in the lower gears due to the engine not having to accelerate such a mass.
You will need a sprung clutch friction plate as you'll be doing away with the dual mass flywheel.
A fair bit of expense and work for very little return, IMHO. Worth doing if you have to replace the clutch but not otherwise.
Remap ECU?
True, except that you'd be hard pushed to get enough power out of a V6 to require any of the fuel system to be uprated IMHO. Certainly not on the budget the OP eluded to.
Best path in this case would be to chip it and perhaps consider 3.2 exhaust manifolds IMHO. Intake setup is identical between 3.0 and 3.2 so no point in messing about there. Throttle bodies are not compatible as the 3.2 is drive by wire. I'm not a believer in porting throttle bodies as the standard ones are plenty large enough for the engine output and it's easy to make matters worse. The same is true of the panel filter also.
Sage words indeed.
Rogusu
« Reply #24 on: 23 February 2011, 14:13:43 »
Remap ECU?
Thanks for help :) I didn´t want to doubt TheBoy´s statement, I justs didn´t know what "do sod all" is :)) I am from Czech Republic and still learning English :)
I am not going to race, I just think this car needs a few more horses to get the right feeling after flooring the gas pedal. It is good now, but I think it should be just a little better:) Cannot explain it, it is just the feeling :) So I was looking for some improvements.
Now it looks like I will get the porting and 3.2 intake at first, then during exhaust change I will also swap exhaust manifold and I will finish it with ECU. Should I use the one mention here: http://www.omegaowners.com/forum/YaBB.pl?num=1293153796?
And I think that will be all. I cannot strap much as I am using this car also for familly trips.
I am just curious, what cams do you know for this engine? I was looking for them, but didn´t find anything :(
Again, thanks for your help :)
Just for the intake. The only reason I am still thinking about it is that I thought the 3.2 is using 3.8bar FPR, which is located near the injectors placed on intake manifold (just saw it on pictures, so I might be wrong). I might have a possibility to take the whole intake system from 3.2 cheap as the seller is unaware of this and I thought it should give me some reserve after better exhaust and ecu upgrade. But if it is placed in another area, I will leave it.
By porting I meant this: http://www.omegaowners.com/forum/YaBB.pl?num=1267996783 so there is no gain? Again, I thought that for very low cost there can be some improvement :)
« Last Edit: 23 February 2011, 14:25:46 by Rogusu »
omegabsw
  • Essex
« Reply #25 on: 23 February 2011, 15:31:55 »
In your first post you talk about the 3.2 throttle body and if they are compatible, as the 3.2 is fly by wire and the 3.0 has a throttle cable I dont think that there will be a lot of it that you can use.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #26 on: 23 February 2011, 16:47:58 »
other rides
omegabsw
  • Essex
« Reply #27 on: 23 February 2011, 17:10:05 »
That will just be a chip from the MSD/GSI Vectra B
Looks worth it for the money tho
« Reply #28 on: 23 February 2011, 17:14:44 »
In that case, it might not support the Omega's multiram setup.
Chips from ebay are a bit of a lottery, because you've no idea if the code came from a reputable chip that's been rippped-off (and sold illegally ::)) or a copy of something a teenager modified without knowing what he's doing.
Rogusu
« Reply #29 on: 10 March 2011, 15:34:03 »
OK, just for curiosity, I looked up some V8 engines :)
Althought not a GM 5.7 V8 I wanted, I have found some "affordable" 4.4 V8 from BMW. I have also found a mechanic, who agreed to help me. But we do not know, what this conversion can take. Does anyone have any experience with this? What else from engine do I need? What should I expect, avoid etc? :)
Any help will be much appreciated.
Page created in 0.023 seconds with 20 queries.
