Pages: 1 [2] 3  All   Go Down
Author Topic: Can anyone do bodywork repairs?  (Read 8671 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Can anyone do bodywork repairs?
« Reply #15 on: 15 March 2011, 19:55:55 »
cheers cem, i wish id not bothered but is done now so desperately trying to sort it!!!  :-[
RIP Paul Lovejoy
Mysteryman
« Reply #16 on: 15 March 2011, 19:55:56 »
Webby , the problem in the picture needs proper sanding .. and proper painting.. which must be done by a professional..  and color passage on the panel is not that easy..(if you wont paint completely)..
dont try to learn painting on a nice new car ;D :y
He's not Cem. It's his omega he's practising on before he buys a super zaffy. :y
Webby the Bear
  • Northampton
« Reply #17 on: 15 March 2011, 19:56:33 »
 ;D ;D ;D ;D ;D
RIP Paul Lovejoy
tonyyeb
  • Salisbury
« Reply #18 on: 15 March 2011, 20:16:54 »
A reasonable guide would be about £150 per panel, done by somebody proficient in the craft. Take it to a body-shop, and double or triple that.
Webby, If you're serious about getting your car looking really smart, I have a contact for you who'll seamlessly and fabulously repair your cack-handed bodgery for (I'd guess) about £200, but you'd need to get yourself and car over to Andover, Hants.... ;)
« Reply #19 on: 15 March 2011, 20:42:03 »
no worries, can be sorted.. but you need really good references..check the shops finished jobs before you dive in ;) :y
Webby the Bear
  • Northampton
« Reply #20 on: 15 March 2011, 21:17:58 »
thanks guys for the advice.
tony, yeah im interested. would you mind pm'ing?
cheers mate
RIP Paul Lovejoy
r1
  • nottingham
« Reply #21 on: 15 March 2011, 22:26:25 »
webby the secret with this sort of repair is the time and effort you but in.from the looks of things you did not sand your repair down far enough.if you have the cash then go for the proper job but if not you need to sand it all back down again and blend it into the good metal.so when you run your hand over it you cant tell where the filler ends and the metal starts.
tidla
  • solihull
« Reply #22 on: 15 March 2011, 23:10:30 »
give this guy a call.
« Reply #23 on: 16 March 2011, 21:55:26 »
Pretty much, yes.
Similar to using clays and such whereby surface contaminants are removed alongwith scratches etc leaving a really smooth surface that looks first class once sealed and polished properly.
thanks h21.... see, if i can do that then i can save myself £200!!!!!
so literally just polish with t cut and it will bring off the overspray?
cheers mate
OMG - it looks really cr*p now you've removed masking.
You really need somerthing a bit more agressive than T-cut - use a rubbing compound which will take off and smooth result of overspray.
Ideally you should have properly cleaned surrounding panels using a rubbing compound before spraying, as now if you try to remove the overspray you will end up with a "line" where the new paint meets the old "dirty" paint.  So you won't save yourself the cost (£200) of putting this right by T-cutting or removing overspray.
In fact you have probably increased the cost of proper repairs now as you have "mucked up" the bumper, and the rear door which will need sorting as well as the rear wing/arch. :(
Good bodywork repairs require a lot of good preparation - as you have found out you can't get a good spray finish on poor preparation !
Bet you wish you hadn't started this now  ;)
« Last Edit: 16 March 2011, 21:59:19 by dbug »
cannonfodder
  • Leicester
  • Never ever Blimin anything ever
« Reply #24 on: 18 March 2011, 17:49:19 »
got a similar one, except my back wings got a huge dent in it thanks to some *********  , anybody know,( i know its a welded on back wing), is it much of a job, expensive to replace the whole wing rather than repair?
Sipey
  • Maidenhead
« Reply #25 on: 19 March 2011, 21:35:24 »
Hi Webby,
If you can get to Maidenhead I can fix it for you and provide you with a car to keep you mobile. PM me if you still need a hand bud.
Regards,
Mark
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #26 on: 21 March 2011, 10:25:40 »
Fair play for having a go at the body work although it's not something I personally would have tackled with no previous experience... it's not like regular spanner-ing, you need a bit of artistic talent too, plus experience is a must if you want to get good results.
The over spray to the door and bumper should polish out, although you'll be there a long time with just T-cut, better to use proper cutting paste and a machine polisher.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #27 on: 23 March 2011, 17:48:47 »
Blimey sipey thats a fair offer! well done to you sir, webby would be a plonker to refuse that one, come on webby take it up man quick. :o
Jaguar XJ6
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #28 on: 23 March 2011, 19:23:37 »
Is Sipey a pro bodywork specialist that would do mates rate?  If so I have a lot of work for him  :y
Sipey
  • Maidenhead
« Reply #29 on: 23 March 2011, 19:29:06 »
Send me a PM mate and we can have a chat  :y
Pages: 1 [2] 3  All   Go Up
