Author Topic: Thanks to Mr irmscher and Mr Bilstein  (Read 2154 times)
« on: 26 March 2011, 20:19:57 »
Billys and irmys fitted all round today. Love it, still needs set up, although got camber and toe fairly close on the front. The ride is firm but compliant with minimal body roll. How did they manage that?
Oh and thanks to Phil for the springs, brand new unused irmscher springs. Felt guilty fitting them, should have put them on the mantel piece.  :D
Bilstein B4 shocks, recommended by The Master and Pink among others.
Thanks guys.  :-*
Re: Thanks to Mr irmscher and Mr Bilstein
« Reply #1 on: 26 March 2011, 20:33:52 »
They are a very good setup, not excessively hard yet loads more feedback and better road holding
« Reply #2 on: 26 March 2011, 20:45:18 »
.....  should have put them on the mantel piece.  :D
MrsGixer would have been pleased!  ::) ::) ::) ;D ;D
damon80
  • Wigan
« Reply #3 on: 26 March 2011, 21:20:33 »
At least they're clean!!  :D
2woody
  • Northumberland
« Reply #4 on: 26 March 2011, 22:26:23 »
I need a drive of that, then.
same car as last week ?
« Reply #5 on: 26 March 2011, 23:48:45 »
Kept or disposed of Self Levelling?
I REALLY need some Irmscher springs :(
« Reply #6 on: 27 March 2011, 00:00:13 »
Binned SL. Did the front first then the rear, which gave the most improvement!
« Reply #7 on: 27 March 2011, 00:11:13 »
Yep. Steering wheel now central. Steering lock off to the right though  :-/
« Reply #8 on: 27 March 2011, 00:13:24 »
Mrs G likes a trophy or two.  :y
« Reply #9 on: 27 March 2011, 11:07:37 »
Thats suggests the column is not aligned to the steering box correctly and the wheel has been moved to correct it.
« Reply #10 on: 27 March 2011, 11:48:24 »
yeah..."We" looked into all that last week with 2woody. The column and knuckle(?) to steering box shaft had all been disturbed by the looks. Chewed torx bolt on on knuckle clamp to steering box shaft and one of the sheer bolts still had the hex attached. It was definitely off centre when it came to me by some way, as the steering lock position was off to the left, it's now off the right, so we may have gone to far, or I haven't got the steering wheel back on accurately to the knuckle position as that part was left to me as it was late and the curry house was open.  ::)
I have yet to look underneath and see if the pitman arm is straight ahead ish.... And although there are lots of splines on the steering column, the increments are still too wide to get it cock on, it needed half a spline right, maybe should have gone half a spline left once the column was adjusted to the mark on the box shaft? What a fiddle!
This was all in aid of finding a knock in the steering, we found a loose or worn steering knuckle on the drivers side wishbone. Replaced it, and it's better in that the knock is no longer present over bumps, but there is still a slight tap when turning the steering wheel to the left.  :-/
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #11 on: 27 March 2011, 13:45:42 »
Yep that Irmscher and Bilstein is very nice set up ;) :y.
