Author Topic: astra 2.0 dti  (Read 1961 times)
mantagte
  • great yarmouth
    • omega bmw maverick
astra 2.0 dti
« on: 26 March 2011, 18:10:03 »
2004 90000 miles
is there anything in particular to look out for
are there any known mechanical problems
TIA
SJKOO01
Re: astra 2.0 dti
« Reply #1 on: 26 March 2011, 18:57:41 »
Fuel pumps are known to be a weak point, so if the owner doesn't know how old it is or won't say, you need to bear in mind if they need replacing it can cost I think around the £100 mark to replace.
Maybe a bartering point  ::)
    • 530D M Sport, 330i Coupe
Re: astra 2.0 dti
« Reply #2 on: 26 March 2011, 19:02:15 »
Add another 0 to that.....!
SJKOO01
Re: astra 2.0 dti
« Reply #3 on: 27 March 2011, 11:34:18 »
Seriously  :o . Glad I didn't go and buy a diesel van myself about 4mths ago.  I knew they were expensive, but not that EXPENSIVE!
Re: astra 2.0 dti
« Reply #4 on: 27 March 2011, 12:17:11 »
The trick with the DTi's is the service history. Find one that hasn't had regular servicing..... walk away.
Also adding a little 2 stroke oil into each full tank of fuel helps keep the pump lubricated.
There are plenty of these engines running round with 250K+  :y
mantagte
  • great yarmouth
Re: astra 2.0 dti
« Reply #5 on: 27 March 2011, 15:11:06 »
are there any signs a pump is on its way out
or do they just give up?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: astra 2.0 dti
« Reply #6 on: 27 March 2011, 20:32:44 »
Not really necessary, even modern diesel with all it's added 'cleaners' is still quite slippery. These pumps only usually suffer mechanical damage if the fuel filter bowl is allowed to run dry...
They just give up.
One minute the car is fine, the next it won't start. Ever.
As 'VXL V6' says though, there are PLENTY of these pumps around and not only are they attached to Vx. engines, BMW, amongst others, also use them.
Some info here...
http://www.bluechipdiesel.com/injectionpumpfailures.html
Re: astra 2.0 dti
« Reply #7 on: 27 March 2011, 23:18:28 »
If this is like the 1.7 DTi which I'm 99% sure it is, The fuel pumps themselves aren't actually the issue, a lot of the time it's  the fuel pump ECU which again a lot of the time is repairable, it cost me £125 Inc VAT to have mine sorted on my Combo van before.
Also there is no way to tell really, mine juddered on the Monday when I put my foot down leaving a roundabout thought no more of it, Wednesday it done it again, then Friday it cut out doing 70 down the motorway then the following Monday I was at the side of the road and it wouldn't start, very annoyingly that day someone had bought it off eBay and was coming the day after. That was the quickest fuel pump ECU the man had ever done  ;D
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
Re: astra 2.0 dti
« Reply #8 on: 28 March 2011, 20:37:43 »
Yeah from my experience i've seen plenty of pumps go on these cars.
Seems as though the big money as mentioned above is coding.
Pump itself can be quite cheap.
