Author Topic: What a waste of an evening, thermostat.  (Read 4993 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: What a waste of an evening, thermostat.
« Reply #15 on: 23 March 2011, 10:19:26 »
They have given you the late seal ring which is incorrect for that stat.
For the stat you have you need 90502258 seal ring and new bolts 11094901
Andy
Oh and transfer pipe seals 9129999
I can't see that part number for the seal ring on EPC.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #16 on: 23 March 2011, 10:26:01 »
I'm going to take it all back to the dealers, now.
Will report back later.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #17 on: 23 March 2011, 11:32:30 »
Right thermostat, wrong 'O' ring, parts sorted (hopefully).
Thanks for everones input :y
I like red cars
« Reply #18 on: 23 March 2011, 11:39:51 »
Both of the options are the right stat AA, but the one with teh thinner flange is the poorer quality one.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #19 on: 23 March 2011, 12:51:54 »
It's the only one now stocked, so I'm led to believe.
I like red cars
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #20 on: 23 March 2011, 17:57:44 »
But why did you not put some sealant/black goo instead of the o-ring? WOuld have saved you a lot of hassle, wouldn't it?  :-/
« Reply #21 on: 23 March 2011, 18:16:58 »
It's not that easy, as the area around the stat seal is recessed.
I am also feeling incredibly guilty. I remember late last year I offered to help with this job, and completely forgot about it  :-[
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #22 on: 23 March 2011, 19:17:25 »
The stat housing has the groove for O-ring and the mating surface in the vee is flat. So, putting the sealant to the housing side and tighten up, why it would not work?
No, I do not admit (yet  :'() having done this to my car because the aftermarket stat leaked with its own O-ring  :-[
« Reply #23 on: 23 March 2011, 19:23:06 »
If you want to fill a groove with sealant, rather than an O ring - crack on.
I won't be following suit!
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #24 on: 23 March 2011, 19:39:14 »
Not saying rather, no! But in my case, as the housing and seal were that poor and did not have the original parts on hand I had no choice... And that's what I meant for the OP also, if it will work it would have saved some hassle  :y Or am I completely wrong with my "solution"? I know you SHOULD use the correct parts and methods and I also respect them, genuine cam cover gaskets, genuine or Gates belts etc...  :y
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #25 on: 23 March 2011, 23:36:24 »
ote author=5F5758340 link=1300866164/24#24 date=1300909154]
Not saying rather, no! But in my case, as the housing and seal were that poor and did not have the original parts on hand I had no choice... And that's what I meant for the OP also, if it will work it would have saved some hassle  :y Or am I completely wrong with my "solution"? I know you SHOULD use the correct parts and methods and I also respect them, genuine cam cover gaskets, genuine or Gates belts etc...  :y[/quote]
bodging is all well and good but i must say when it comes to the coolant or any other sealing system i believe you need to be thourough but i get what your saying with what's to hand i've certainly been in that situation!
Warning: Dates in Calendar are closer than they appear.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #26 on: 29 March 2011, 06:57:55 »
Welung came over last night, thermostat sorted :y
Note - if anyone buys a thermostat from a dealer, make sure they give you the round 'O' ring, as there are 2 part numbers quoted on EPC.
I like red cars
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #27 on: 29 March 2011, 11:03:53 »
Mine had in the original stat flat -sided "o"-ring, e.g. the cross section was merely square and it had some grooves also on the mating surfaces  :-/
