Pages: 1 [2] 3  All   Go Down
Author Topic: LPG bits for the Elite  (Read 5096 times)
Re: LPG bits for the Elite
« Reply #15 on: 30 March 2011, 12:56:37 »
Tunnie, given that they are nylock nuts, not sure I would have bothered with antishake washer, allowing the nylock to grip more...
Blame Lazytinker, I was just a useless student doing what he was told :P
« Reply #16 on: 30 March 2011, 13:08:16 »
Would you believe it, I can't find a rather ruler anywhere ;D
Found the bolts Teilo supplier, look to be around 8cm as a guess, so he's provided the same as last time.
Tunnie's certainly look longer, and without antishake washers, look to be long enough.
I might try to pick up some threaded rod as a backup, but its half day closing around these parts on a Wednesday...
« Reply #17 on: 30 March 2011, 13:34:52 »
I was right, local hardware shop shut ;D
« Reply #18 on: 30 March 2011, 13:35:47 »
I told you they were crap! Never, ever open when you want them to be  :(
« Reply #19 on: 30 March 2011, 13:37:39 »
Just don't go Wednesday afternoons, Saturdays after about 2:30 or Sunday then ;D
« Reply #20 on: 30 March 2011, 13:41:20 »
I'm still not convinced that vaporisor is ideal for a 3.0 V6  :-/
I thought Tielo was going to be providing something more substantial, like this:
« Reply #21 on: 30 March 2011, 13:43:39 »
I would only get up at 12 on Saturdays, so that was part of the problem  ::)  ;D
« Reply #22 on: 30 March 2011, 13:45:04 »
Its probably around the same size as my existing one in the MV6, and thats trouble free - certainly not seen the lag issues that Lazytinker and chrisgixer see, just a horrid gearchange at 6750rpm (very horrid at 3rd to 4th).
chrisgixers lag is a different kettle of fish to lazytinkers, and due, I reckon, to the later engine ECUs - the lag is there, to a lesser extent, on petrol.
« Reply #23 on: 30 March 2011, 13:45:55 »
Once a student, always a useless student....
« Reply #24 on: 30 March 2011, 14:03:41 »
Problem is, even if you get up on time, it gives you just long enough to get into a DIY job and then realise you've lost / mullered a vital part. ::)
« Reply #25 on: 30 March 2011, 14:25:33 »
Sounds like a perfect excuse not to do any DIY around the house :y.  Besides, I like magnolia more than Mrs TheBoy does, obviously ::)
« Reply #26 on: 30 March 2011, 18:26:52 »
I've got a load of bolts... The thread on them is a bit close, hence the anti shake washers to pad it out a smidge ;)
Vaporiser... Not sure which one you got in the end. Does it say? Whichever way, we're testing it on yours ;) If it has the lag he will replace it if required :y It is a faster reacting vaporiser and tested (not just rated) to 312bhp IIRCC
As per PM, I'm available pretty much any time and willing to come and take the piss watch help do whatever I can... Not a lot TBH
« Reply #27 on: 30 March 2011, 23:28:32 »
Lag is indeed there on petrol on my current car, mostly evident on lift off from wot.
Also drove that BRC LPG 3.2 last week that I mentioned elsewhere, it has very slight lag on wot gear changes, but very slight and very gentle. The BRC has a feature that introduces injectors one at a time so any jolts or power increases when switching over are ironed out, seems to work in that it gets round the problem rather than solving it. Certainly not a jolt as experienced previously.
I'd be happy with lag at that level.
Vap is BRC's own branded and there some other little black boxes around the engine bay, plus extra vac references to the plenum. Injectors lead to what appears to be straws in the top of the plenum.  :-?
« Last Edit: 30 March 2011, 23:32:54 by chrisgixer »
« Reply #28 on: 01 April 2011, 12:49:48 »
So does the Stag 300. :y
« Reply #29 on: 01 April 2011, 12:55:54 »
BRC also have timing processors, which I may well be fitting to mine soon to see if it resolves the problem/improves economy
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
