Author Topic: Yesterday, I was mostly....  (Read 4814 times)
Re: Yesterday, I was mostly....
« Reply #15 on: 01 April 2011, 19:04:28 »
Is there room to site telematics in the first aid cupboard too?  :)
I'd say the TM wouldn't fit along side amp.  Unless you fabricated a large amp mount, and mounted TM above amp. Would look messy, but its hidden. You'd then need to remove the cage part that is on the fold down flap bit (that the 1st aid kit sits in).
Personally, seeing how useless the Omega Glovebox is, and the amount of storage in the facelift doors, if I were to fit a TM, it'd be in the glovebox...
Only place to store CD's is in glove box, no? CD's do fit in the glove box.... Don't they? Must do.  :-/ so long since I had use of it.  ;D
How custom is the custom loom i'm making for your custom install of your custom telematics in a custom place?  ::) ;D
It may be easier to build the front end of the loom up, install it and put the connectors on for the rear install afterwards.......
One point to note, I wouldn't mount the telematics or it's aerial cable to close to the Bose amp and it's cabling otherwise you might suffer some interference issues.
Ultimately looking to sort an ac glovebox
« Reply #16 on: 01 April 2011, 19:17:12 »
Ducting from the heater or a load of these?
http://www.virtualvillage.co.uk/pack-of-10-91-2w-thermoelectric-coolers-S01540-002.html?utm_source=googlebase&utm_medium=shcomp
« Reply #17 on: 01 April 2011, 19:31:56 »
Well initially ducting, but ...  :-/
« Reply #18 on: 02 April 2011, 09:42:19 »
Pre minifacelifts often had A/C gloveboxes... ...never bothered checking where it picked the chilled air from though.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #19 on: 02 April 2011, 19:34:21 »
Knowing Vauxhall it'll probably be the same as on a Vectra 'b', the chilled air is fed into the glove box via a tube from an outlet on the rear of the heater matrix enclosure.
The last Omega I took apart had a tube that appeared to feed cold air to the rear of the stereo, maybe look where that originates from?
