Author Topic: Omeage Satnav  (Read 2124 times)
Omeage Satnav
« on: 04 April 2011, 20:41:15 »
The none colour version.If transferring it from one car to another, what is involved exactly ? presumably more than just the display ?
Does it need to be reprogrammed via tech2 or is it just plug & play ?
Tia.
Re: Omeage Satnav
« Reply #1 on: 04 April 2011, 20:47:17 »
Sorry Albs, the CARiN type, or the NCDx but with GID display?
Re: Omeage Satnav
« Reply #2 on: 04 April 2011, 20:52:58 »
Youve lost me. ::) ;D ;D...........its in a 52 plate Elite and shows the Bose logo when the ignition is switched on. Other than that I dont know. Might have to put a battery on the car tomorrow and try to find out a bit more. :-/
If that fails, I might have to buy one of those new fangled digital camera things, and work out how to invoke the necessary witchcraft to get the pictures from inside it onto the interweb. :-[ ;D
« Last Edit: 04 April 2011, 20:55:55 by albitz »
Re: Omeage Satnav
« Reply #3 on: 04 April 2011, 20:56:04 »
Ah, and NCDC201x with a GID then ;D
What are you fitting it in?
Re: Omeage Satnav
« Reply #4 on: 04 April 2011, 20:57:23 »
Im not. I will be selling it, but I dont really know what Im selling. I presume its more than just the display itself ? :-/
Re: Omeage Satnav
« Reply #5 on: 04 April 2011, 21:00:02 »
Optiotns:
1) The display, the NCDC201x and the telematics (if fitted) all need to be kept together, preferrably with the pairing code from carpass.
2) Depair everything and sell as depaired seperate units.
Re: Omeage Satnav
« Reply #6 on: 04 April 2011, 21:17:19 »
Where do I find the other bits apart from the display please ?
Is the roof ariel part of the setup ?
Should the car have a phone in it, and if so is that also part of the same setup ?
There is a phone cradle inside, but it looks like something which has been added by an owner rather than OE.  :-/
Sorry to sound so ignorant on these matters, but both my Omegas have been CD spec, so dont know much about the luxury items. ::)
Re: Omeage Satnav
« Reply #7 on: 04 April 2011, 22:23:22 »
Display - in dash, obviously
NCDx - in the centre console, obviously
Telematics - filling the glovebox (take the glovebox with it), and aerial on roof
Bose amp/wiring/speakers - covered many times before, if you need locations, just shout :y
To fit this into another bose equipped car needs a minor mod to wiring behind NCDC201x (best done on a TM loom) and a minor mod to the display. To fit in non bose car, needs a tech2 chat as well
Re: Omeage Satnav
« Reply #8 on: 04 April 2011, 22:33:58 »
Great, thanks Jaime. :y
charlie
  • sunderland
Re: Omeage Satnav
« Reply #9 on: 04 April 2011, 22:41:40 »
YOu will need the gps lead from kick panel to back of the radio cage aswell,which is a right pain in the A** TO get out of the harness
Re: Omeage Satnav
« Reply #10 on: 04 April 2011, 22:54:52 »
Cheers Charlie. :y
Re: Omeage Satnav
« Reply #11 on: 04 April 2011, 23:04:02 »
....and all the co-ax cabling from the blue connector behind kick panel back to roof aerial :y
Re: Omeage Satnav
« Reply #12 on: 04 April 2011, 23:11:20 »
I thank you Rob. :) :y
