Author Topic: EGR Problems  (Read 2755 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
EGR Problems
« on: 06 April 2011, 19:50:52 »
With Mrs Loo-knee's Discovery.......
Ever since she has had it in the morning it is so sluggish for the first 100 yards its un true, but she got used to it thinking that was how these Diesels were...
Mothers Day we went doing the rounds when the Disco was going so slow a woman pasted us pushing a a pushchair ... well almost  ;D ;D ;D The smoke coming out of the back was so much the following cars had their headlights on  :o also showing their displeasure with more than a peeping of horns  ;D ;D
Monday I removed the EGR Valve blanked it off, it now is like a different car, unbelievable....
Re: EGR Problems
« Reply #1 on: 06 April 2011, 20:17:43 »
What else did you touch while you where in there?  :)
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: EGR Problems
« Reply #2 on: 06 April 2011, 20:18:49 »
How did you know Mrs Loo-knee was there? anyway none of your business you nosey Git  ;D :P
Re: EGR Problems
« Reply #3 on: 06 April 2011, 20:19:58 »
Oh I say, that's not what I meant at all.  ;D
Re: EGR Problems
« Reply #4 on: 06 April 2011, 21:39:48 »
EGR has a major impact on diesels as when its stuck open it means the exhaust pressure is lower resulting ina  turbo that wont spin up.
Having said that, its pretty essential on modern diesels as it makes them warm up SO much faster.
Re: EGR Problems
« Reply #5 on: 06 April 2011, 21:43:51 »
Makes a huge difference on my TD Astra when it sticks ........ & the EML is on.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: EGR Problems
« Reply #6 on: 06 April 2011, 21:47:43 »
I have been told to get a De Cat pipe for it too that will help :-?
Arrolman
  • Renfrew,Scotland
Re: EGR Problems
« Reply #7 on: 06 April 2011, 21:54:02 »
Hi Daz,
Yes, gives it a bit more power, also make sure the intercooler is clean and turbo hoses are all ok, have a habit of de-laminating on the inside. Other than that theres not much else to help them go any better lol
Cheers,
Iain
Looking to win the lottery..........
Re: EGR Problems
« Reply #8 on: 06 April 2011, 21:56:02 »
Struggling to see how a decat alone can give any more real power as the ECU is controlling the fuel in and the boost pressure is limited......I am sure it would help with other mods though.
Arrolman
  • Renfrew,Scotland
Re: EGR Problems
« Reply #9 on: 06 April 2011, 21:59:06 »
Hi,
I believe its a 300Tdi that Mrs loo-knee is running, no ECU on that engine unless an auto :y
Iain
Re: EGR Problems
« Reply #10 on: 06 April 2011, 23:24:46 »
I thought you were banned..... :D :D :D
Debs.
Re: EGR Problems
« Reply #11 on: 07 April 2011, 10:14:07 »
 ;) Not in the early 300tdi`s: the pump output can be 'tweaked' and the waste-gate arm 'adjusted'......How-to`s on most of the Landy forums. :y
....is the 'Cat' on a tdi not just a particulate filter and as such; prone to eventual partial/total obstruction? :-/
« Last Edit: 07 April 2011, 10:27:43 by Debs. »
Re: EGR Problems
« Reply #12 on: 08 April 2011, 08:19:49 »
I am sure it can be tweaked but, removing a cat is not putting more fuel in and hence power will NOT increase  :y
Similarly for a larger intercooler, that will in theory get denser air in but....with out fuel its a fools errand
Debs.
Re: EGR Problems
« Reply #14 on: 08 April 2011, 20:28:09 »
200/300 Tdi Bosch VE Mechanical Diesel-Pump tuning tips:
http://www.dividingcreekroverimports.com/technical_info_from_the_web
http://www.landroverweb.com/Pdf-files/Tuning_Land_Rover_Tdi_engines_Rev_2.pdf
Exactly, it describes getting air in and then specificaly mentions how to add the fuel to get the performance.
Ergo, decat and larger intercooler does jack on its own.
Simples!
