Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: TheBoy's magic fuel tank...  (Read 10701 times)
Re: TheBoy's magic fuel tank...
« Reply #15 on: 13 April 2011, 20:50:21 »
I certainly would not be running it out of petrol by driving it? if its got to come out then it wont weigh much now, not worth the hassle of sucking a load of crap into the lines and filters etc?
LPG, buddy ;)
« Reply #16 on: 13 April 2011, 20:51:09 »
You still faffin around getting that poxy V6 to run on gas? The joys of 4pot, simple install, no lag!
Nope... Runs fine. Just got to sort the very slight leak from one of the valves on the tank ;) ;)
« Reply #17 on: 13 April 2011, 20:51:41 »
It runs fine on LPG. Very well.
The problem is, it uses LPG even when its turned off ::)
« Reply #18 on: 13 April 2011, 20:54:29 »
But obviously not much if it's still not empty ::)
« Reply #19 on: 13 April 2011, 20:55:25 »
Did you fit another tank in the spare wheel well and forgot about it :-*
After all the currys, maybe CG and LD have farted in it....
Just because you were having "confidence" issues ;D ;D ;D
Sunday morning, that was a bit or an ordeal....  :-[
 ;D ;D ;D ;D ;D ;D ;D
I can only laugh because it wasn't my ordeal :P :P :P
« Reply #20 on: 13 April 2011, 22:22:35 »
No smoking around the Elite then, actually no, lets all spark one up!  8-)
« Reply #21 on: 13 April 2011, 23:31:54 »
Even though your plenty tall enough to reach the stop, the pedal does have to be pressed to get the lag. Ie, somewhere above tick over.  :P;)
« Reply #22 on: 14 April 2011, 09:49:02 »
The argument of course could be that the 4pot has no power to create lag  ::)
When i get my Monaro/VXR8 we will see who will have 3/4 of an engine  :P ;D ;D  :D
« Reply #23 on: 14 April 2011, 09:58:30 »
Tunnie, get a proper M5..
« Reply #24 on: 14 April 2011, 10:03:05 »
Or just that yours is a manual, which has different characteristics on gearchange ;) ;)
« Reply #25 on: 14 April 2011, 10:06:37 »
You mean a proper gearbox removes the fault?  :-X :-X  ;D
« Reply #26 on: 14 April 2011, 10:10:31 »
I wouldn't refer to any omega manual box as proper... But of course it does as you control the injector timings with your right foot, and it's much slower to change than an auto, which cuts injector times to limit the torque on change ;) ;)
« Reply #27 on: 14 April 2011, 10:17:45 »
thats why I always like a manual, as I control how fast/slow the change is, and most importantly it changes gear, when I want it to!
VXR8 manual with LPG?  :D
« Reply #28 on: 14 April 2011, 10:25:32 »
But the Omega manual box is horrible ::) ::)
« Reply #29 on: 14 April 2011, 10:30:27 »
I like it, the throw is a little long, but I like fact can rest my arm on the arm rest in most gears.
Pages: 1 [2] 3 4 5 6   Go Up
