Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: TheBoy's magic fuel tank...  (Read 10706 times)
Re: TheBoy's magic fuel tank...
« Reply #45 on: 14 April 2011, 21:06:57 »
Hopefully that will sort it then :y :y
Pop 5l in, bring home, then check for smell?
Hmm... Tricky one that. Id didn't start leaking until it was full before :-/ :-/ But I'd be wanting to start with less than a full tank this time ::) ::)
When you do fill it, keep an eye on the pump in case the shut off doesn't cut in like before ;) ;)
Tempted to put just a little in, check, then perhaps half fill it, check again, then fill to 70% on gauage, check, then let it run out again, and fill to full or 65l, and adjust tank as reqd
Sound like a superplan?
« Reply #46 on: 14 April 2011, 21:26:51 »
Sounds like the best plan you can really use ;)
« Reply #47 on: 14 April 2011, 22:44:43 »
Got a can of gas leak detector spray  ::)  if it helps. Spray on, blows bubbles from the gas escaping. Probably the same as soapy water though.  :-/
« Last Edit: 14 April 2011, 22:45:07 by chrisgixer »
« Reply #48 on: 14 April 2011, 23:06:49 »
It is soapy water ;) ;) ;)
Like I said, trouble is that it didn't leak until it was full and had been in there for 5 mins or so ::) ::)
« Reply #49 on: 14 April 2011, 23:26:40 »
Aha, different apparently :-/ doesn't corrode or sumat. De ironized maybe. ..?
« Reply #50 on: 14 April 2011, 23:49:47 »
I'd guess that it's oil based in some way :-/ :-/
« Reply #51 on: 15 April 2011, 10:41:28 »
My can of gas leak detector from shitfix is, errr, shit
Back to nostrils for me
« Reply #52 on: 15 April 2011, 10:42:59 »
As I said on Sunday... The best leak detector for LPG is the Mark 1 Nose and Ears ;) ;) ;D ;D
« Reply #53 on: 15 April 2011, 10:44:43 »
are you sure the gas escaping is not from a certain curry?  ::)   ;D
« Reply #54 on: 16 April 2011, 08:35:16 »
Popped 10l in the tank, no sign of leak in the gas tight box :D :D, so now need to add a bit more. Might pop it straight up to 65l.
The downside, is both Mrs TheBoy and I are convinced there is a leak from front end, we both reckon around the 1/3/5 bank, though it could be from vap/filters, anywhere really.  Don't think its 2/4/6 bank. Can't seem to pinpoint further though - nothing seems to be visibly leaking, and the shitfix leak detector is as much use as a used johnny smeared in dogshit.
« Reply #55 on: 16 April 2011, 09:28:48 »
Really? I'd be very surprised if there is :o Certainly wasn't any sign of a leak on Sunday ;)
Sure you're not being a touch paranoid?
« Reply #56 on: 16 April 2011, 09:32:59 »
We both smelt it it bonnet open. Smell seems to go when on petrol, and I reckon return after a few seconds of running on *any* lpg injector, making me think:
liquid filter
evap
gas filters
injector blocks
hoses
« Reply #57 on: 16 April 2011, 09:33:27 »
just cant pinpoint it though, other than it is defo 1/3/5
« Reply #58 on: 16 April 2011, 09:55:58 »
After the faff with the tank valve I think I'd be looking around the liquid phase filter :-/ check the bowl on it hasn't worked a little loose with all the trial fit/re-fit, remove, fit again ;)
Can't see it being a vapour phase leak with how tight the hoses were
« Reply #59 on: 16 April 2011, 09:58:01 »
After having another sniff, I'm wondering about injector block.
LPG gas is heavier than air, isn't it (though with the heat in engine bay, who knows  :-/)
Pages: 1 2 3 [4] 5 6   Go Up
