Author Topic: Astra Diesel breakdown - help !  (Read 1482 times)
Big_Al
« on: 22 April 2011, 18:11:05 »
hi guys ,   neighbours T reg 1.7 diesel Astra van,  came to junction across the road from here & just died. Pushed it to outside of his house.
Turning over fine but will not start. Half tank of fuel,  no management light.
Any pointers would be great. TIA   Al :y :y :y :y
Re: Astra Diesel breakdown - help !
« Reply #1 on: 22 April 2011, 18:19:31 »
Check for fuel/leaks at the injectors will be the best place to start ;) ;)
If it was running fine it sounds like the shut off solenoid has activated... May be a fuse, may be a broken wire but checking for fuel is the best start (assuming it's not turning over quickly... i.e. Cam belt ;))
Big_Al
« Reply #2 on: 22 April 2011, 18:33:41 »
Gonna give  him half hour of my time -  last thing I want tonight is to get covered in diesel. >:( >:(  Just trying to point him in the right direction -  :y :y :y
« Reply #3 on: 22 April 2011, 18:37:27 »
Guessing it's a low blow 1700 single over head cam diseasal - X17DTL. Get a code reader on it, good chance it'll be the fuel pump (can't remember the code  :-/). As they're a fortune new there's loads of dead 1.7 TD Astras around. I got a recon'd pump for £350 for mine.
« Last Edit: 22 April 2011, 18:40:06 by Andy_B »
Big_Al
« Reply #4 on: 22 April 2011, 18:39:31 »
Thanks Andy.   could really do without this tonight  ::) ::) ::)
