Author Topic: what will it pull  (Read 5038 times)
Re: what will it pull
« Reply #15 on: 25 April 2011, 10:46:40 »
sounds like you want a landrovr discovery a rangerover or transit van for that size and weight.paul
can a transit pull 3 ton?
No. I think they have a train weight of about 3.5 tonnes (an Omega is higher at around 4). Subtract the weight of the van and its' load and it won't pull 3 tonnes.
In any case, I wouldn't tow anything with a van unless the van itself was well loaded.
A Disco can tow 3.5 tonnes, IIRC, so that might be an option.
« Reply #16 on: 25 April 2011, 11:15:19 »
Ime transits can barely manage on their own if empty, and great fun a hand full in the wet, add in a pikey palace on the back and must be looking at an easy jack knife...?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17 on: 25 April 2011, 12:00:52 »
You must have driven some seriously knackered vans!
Any healthy turbo Transit has no problem pulling lots of weight, but you do go through brakes pretty quickly.
« Reply #18 on: 25 April 2011, 12:12:26 »
Hire vans mostly, all very scitish when empty. As expected given the designed load capacity...
