Author Topic: 6 speed box ?  (Read 5803 times)
Thomas-Elite
  • south wales
  • High BHP Hero
6 speed box ?
« on: 30 April 2011, 20:18:47 »
Any mechanical guru's know what six speed box will fit the 3.0  omega? f28? would like to keep my clutch because its a mega one and it cost a fair pop, has only covered a few k miles. dont like the standard box due to being so long. With the map and cams in my car alot of the power is from about 5k up. If i could get someting to keep it in that power band it would be good  :) Any input would be grate cheers guys  :y
Wolf In Sheep Clothing
Re: 6 speed box ?
« Reply #1 on: 30 April 2011, 20:53:06 »
If the power's higher up you probably don't want a 6 speed box, certainly not from a modern car ;) ;)
Thomas-Elite
  • south wales
  • High BHP Hero
Re: 6 speed box ?
« Reply #2 on: 30 April 2011, 20:56:24 »
Wouldnt a six speed box have a closer ratio?
Re: 6 speed box ?
« Reply #3 on: 30 April 2011, 21:05:26 »
Some do, some don't - obviously you want one that is.. but if you take the MR2 for example, when Toyota added the 6th gear in 2003, all they did was add a longer gear for cruising and left the rest the same. Then again, it was already a very short-geared box.
None of which helps you in your quest to find a close-ratio 6 speed that'll mate to the Omega  :-[
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
Re: 6 speed box ?
« Reply #4 on: 30 April 2011, 21:05:40 »
Isn't the F28 for FWD ?
Thomas-Elite
  • south wales
  • High BHP Hero
Re: 6 speed box ?
« Reply #5 on: 30 April 2011, 21:13:31 »
 :-/ yea it is.
omegadan67
  • northampton
Re: 6 speed box ?
« Reply #6 on: 30 April 2011, 21:42:18 »
 :-/ yea it is.
  if for fwd wont fit a rwd. best bet is a ford mtx75 5 speeder from a seirra cossie
A little infomation is dangerous in the wrong hands
Re: 6 speed box ?
« Reply #7 on: 30 April 2011, 21:45:32 »
Ford box in a GM car !! wash your mouth out Dan. :D ;D ;D
Re: 6 speed box ?
« Reply #8 on: 30 April 2011, 21:56:33 »
Can't you find a BMW gearbox that'll fit?
Re: 6 speed box ?
« Reply #9 on: 30 April 2011, 21:59:21 »
 :-/ yea it is.
MT75. :y
(The MTX75 was the FWD version.)
Still not a close ratio box by any means, although superior to an Omega box in the quality of shift, IMHO. Tediously short first gear, very limited alternative gearkits available and the integral bellhousing would make it hard work to mate to a GM V6 IMHO.
The type 9 has a good selection of gearkits available, and GM pattern bellhousings can be fitted, but I fear it wouldn't be strong enough. :-/
Re: 6 speed box ?
« Reply #10 on: 30 April 2011, 22:05:37 »
I'm sure you could get a Tremec T56 with gear ratios you're looking for, and have a bell housing made up to suit - even the 'littlest' one will handle 330lb/ft, and there's always the 'Magnum' if you need >450lb/ft torque cap.
Not cheap, mind, and a little agricultural in it's shift (although a million miles better than the last manual Omega I sat in, which appeared to have the standard Vauxhall Vague-o-Matic gearshift).
Thomas-Elite
  • south wales
  • High BHP Hero
Re: 6 speed box ?
« Reply #11 on: 30 April 2011, 22:14:41 »
What about changing the diff? If i got a diff with a shorter ratio wouldnt that close up all the gears? With my engine i do feel that the box is a big hinderance on its power.
Re: 6 speed box ?
« Reply #12 on: 30 April 2011, 22:22:38 »
It will make the gearing shorter, which may help, but the relationship between each gear and the next is the real problem, and this will be dependant only on the gearbox.
For example, let's say you want to keep the engine in the 5000 - 6500 RPM rev range.
If you change up at 6500 and the engine speed drops to 4500 that is a function of the difference in the two gear ratios. Changing the diff will change the speed at which that upshift is required but the rev drop will be the same, and if that causes a peaky engine to bog down, it always will with those gearbox ratios.
r1
  • nottingham
Re: 6 speed box ?
« Reply #13 on: 01 May 2011, 16:34:41 »
think it might be worth while talking to a g/box specialist as you might be able to alter the ratios in your box to suit you better,also dont forget tyre size will also have a effect as well.
Thomas-Elite
  • south wales
  • High BHP Hero
Re: 6 speed box ?
« Reply #14 on: 02 May 2011, 20:22:55 »
I was thinkging about sticking a 2.0 box on it, but my cars putting out a fair bit of torque and would turn it inside out in a matter of miles.  :-[ but im shur that would give me the affect im looking for. Even if for only a short space of time.
