Author Topic: Air Con Condenser replacement  (Read 2410 times)
v6coop
  • Nottingham
« on: 28 April 2011, 17:19:07 »
2008 2.5 V6 mini-facelift air-con has no gas, dignosed as leaking condenser using tracer dye.
A few questions if I may...
Should I replace the drier as well?
I believe new pipe seals are also needed?
Is fitting straight forward?
Where is it best to purchase good quality at the keenest price?
v6coop
  • Nottingham
Re: Air Con Condenser replacement
« Reply #1 on: 28 April 2011, 17:29:17 »
What about this one? Too good to be true?
Auto Aircon Parts
« Reply #2 on: 28 April 2011, 17:36:32 »
That`s the recommended supplier. Decent quality as well. :y
« Reply #3 on: 28 April 2011, 18:31:25 »
Easy enough to fit - just tedious - you will need to remove radiator first.  Ideally replace drier and make sure the seals you get are for aircon (viton I think)
A 2008 Omega - thats the latest one I've heard of  :-? :-? :) :) ;)
v6coop
  • Nottingham
« Reply #4 on: 30 April 2011, 16:35:34 »
Thanks dbug. I have ordered the condenser so let's see how it goes.
I know it is a while since I last posted but I have managed to put this in the wrong section and made the car 10 years younger than it is (wishfull thinking on my part, but 1998 sounds so long ago now!)
« Reply #5 on: 30 April 2011, 16:40:09 »
....and made the car 10 years younger than it is  ....
You're not the only one today that doesn't know how old their car is .....
for the last couple of days my 91 omega 3.2 has made ....
clicky But Ray has gone the other way & made it older!  :-? ;D ;D
« Reply #6 on: 05 May 2011, 01:53:18 »
Can be fitted without draining rad. But you will need to take out all the intake gubbins to give you enough room to lift the rad up and back far enough to get the condenser out and back in again.
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #7 on: 05 May 2011, 07:25:59 »
Can I have one of these?  ;D ;D ;D ;D ;D ;D
AKA - Mr Bracket
Page created in 0.035 seconds with 20 queries.
