Pages: [1] 2 3 4 5 6   Go Down
Author Topic: 3.5 weeks into TBE's LPG  (Read 11589 times)
« on: 03 May 2011, 21:43:44 »
Seems like last week, but its been nearly a month since 'we' started converting That Bloody Elite to LPG.
Its running really well now, seemingly no loss of power, no lag at high RPM gearchanges like the MV6 suffers, nice and quiet.
It clocked over 59k today :o
Its not been without its teething problems - we've had leaks on the valveset and a leak at the front end, and I've had an oddity with one of the solenoids early on. I still need to retweak the tank yet again, and recalibrate the gauge. Also need to fit a replacement interior trim that got damaged when we did the conversion.
Just need to sort out the suspension issues, then TBE and I will have to learn to like each other.
So thanks to Lazydocker and to chrisgixer for their help in getting this far :y
Re: 3.5 weeks into TBE's LPG
« Reply #1 on: 03 May 2011, 21:48:36 »
Bah, you love it really.  :y
« Reply #2 on: 03 May 2011, 21:56:52 »
The poor MV6 hasn't been used for a couple of weeks, so I took it for a blast this evening....   ....and completely fell in love with it again ;D
TBE is more refined, but the MV6 is far more fun, though I really need to sort those rear bushes ::)
« Reply #3 on: 03 May 2011, 22:10:15 »
Aye?  Oh the dif ones? They are easy, 3 bolts each.
Need a source though.  :-/
« Reply #4 on: 03 May 2011, 22:25:30 »
A certain Hornby enthusiast may have a set (2nd hand I think, but he says in good nick), *if* I can manage to get to Nottingham at the same time he is there ;D - I got caught by the 'model' enthusiasts last time I went there...  ...they are a sad lot ;D
« Reply #5 on: 04 May 2011, 12:59:14 »
Glad to hear it's going well now... Not that I'm that worried ::) ::) [size=18]It's not my car!!![/size] ;D ;D ;D
But it's good to hear it's running well and that we finally seem to have eliminated the annoying lag that has plagued most of the previous conversions :y :y
Might be another one to do soon :-X :-X ::) ::)
« Reply #6 on: 04 May 2011, 13:06:14 »
;D
« Reply #7 on: 04 May 2011, 13:21:05 »
;D
Thought that might get a snigger :D :D
« Reply #8 on: 04 May 2011, 13:32:02 »
I'm gonna kill you. Then, just to make sure, I'll kill you again.
;D
And you.
« Reply #9 on: 04 May 2011, 13:32:58 »
;D
And you.
Ooops... Think we rattled a cage there :-X :-X :P :P :D :D
« Reply #10 on: 04 May 2011, 13:36:39 »
One?  By my calculations, 2, possibly 3  :-X
« Reply #11 on: 04 May 2011, 13:38:53 »
;D
And you.
I will have my chance of revenge...  ...possibly with both of you  :-X
« Reply #12 on: 04 May 2011, 13:44:05 »
Gayboy Gixer's doing his own isn't he? So I calculate 1, perhaps 2 ;) Although I suppose he might want a hand ;D
Just make sure we don't let you loose on the wiring... It takes too long :-X :P ;D
« Reply #13 on: 04 May 2011, 13:45:27 »
Or near the intakes - I owe him a bag of gravel.... ;D
« Reply #14 on: 04 May 2011, 13:51:49 »
For the benefit of others not present, I thought, when we LPG'd TBE, it would be a really good idea to basically put the large GM injector rail to loom plugs on the LPG wiring to make it neater.
It has worked, and it is neater, but would I do that again?
No - its not worth the extra effort*.  Its tight and messing under the plenum using the loom as provided by Teilo, but its hidden, and its simple.
*I wasn't going to bother, but with my ECU location, the only way to get the LPG loom to reach without extending was to go under the TB's, which I wasn't hugely happy with - esp was it will need a cambelt later this year or early next. So as I would have to extend loom anyway to allow entry from the rear of the inlet manifold, I stuck to Plan A
Pages: [1] 2 3 4 5 6   Go Up
