Pages: 1 2 [3]  All   Go Down
Author Topic: LPG Tank Options  (Read 6672 times)
Re: LPG Tank Options
« Reply #30 on: 07 May 2011, 16:22:41 »
Hi guys,
I have LPG already installed in my car (done before I got it), I know nothing about them and reading this thread was interesting.
In idiot language, what is:
Multivalve/ 4 pot and gas tight box? please.
I have a doughnut 50ltr in the wheel well of my estate, thats about all I know and that I get 200miles out of it!  ::)
Basically a multivalve fits into a single hole tank and has 4 functions from the one valve: Fill, feed, level sensor and pressure relief. Because all 4 functions are performed by the same valve the liquid feed can be restricted and general view is that a multivalve isn't good for high demand fuelling.
A 4 hole tank has 4 separate holes for each of the above functions and can deliver a greater flow rate of liquid.
The gas tight box (or vapour box) is designed to contain any potential leak (if the tank over pressurised and had to vent some for example) and vent it safely to the outside of the vehicle via vent hoses :y
Hope that helps :y :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #31 on: 07 May 2011, 17:00:12 »
Hi guys,
Cheers for that Lazydocker, that makes sense to me, lol. Will have a look at mine and see what kit mine is. Saying that I don't really have a clue what I'm bloody looking at  ;D ;D
AKA - Mr Bracket
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #32 on: 07 May 2011, 17:27:30 »
A very good move haveing Kevin do the manifold :y wish I'd have gone that route,my conclusion in the end was its one of those jobs you need practice on before you come good at it (drilling angles etc) and there's also the cost of a thread tap + arbour, 2 drill bits, cutting compound,and thread sealing compound.
Cliffo B
« Reply #33 on: 07 May 2011, 17:52:53 »
Ok L.D. I'll try and put together the final routine, materials and pitfalls, I arrived at for fixing in the tank, it should help a lot once known, a job as complicated as this could possibly be improved on,knowing my  style expect a long read :y
« Reply #34 on: 07 May 2011, 17:55:01 »
Glad you've finally come around to my way of thinking :y :y
You can email it to me if you like... I'm happy to put a how 2 together once I've actually done the job, but not until then ;) ;)
I reckon I'm going to try and get a 630x270mm 72L tank :y :y
« Reply #35 on: 08 May 2011, 10:24:18 »
Though my 3.0l MV6, chipped, is fine on a decent flow multivalve...
hotel21
  • The Kingdom of Fife
« Reply #36 on: 09 May 2011, 22:54:25 »
Couple of Q's.
Is it being filled via the adaptor visible when the tailgate is open?  Guessing not, as that would defeat the purpose of loading an estate to maximum?
What is used for the height packer?  Insulation sheets?  Blockboard or marine ply would add to the weight big style...
Otherwise, looks like a workable concept.   ;)
« Reply #37 on: 09 May 2011, 23:23:52 »
Couple of Q's.
Nope filler mounted elsewhere, tow bar is my position of choice :y
Insulation sheets to raise and then hard board to top it, then re-fit carpet if you choose to :y
« Reply #38 on: 11 May 2011, 12:46:55 »
The dilemma continues...
650x270, 77L tank is £75 cheaper than 630x270 :o :o
Might have to go for the larger one and do the modifications after all! :-/ :-/
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #39 on: 11 May 2011, 14:11:59 »
is it viable to chop the bottom out of the wheel well and get the tank lower so as not to lose so much load area?
other rides
« Reply #40 on: 11 May 2011, 14:17:47 »
Not really, there's not a lot of clearance between the wheel well and the tank.
That's not a concern to me, it's just getting the air tight box into the well that's an issue
There are smaller tanks available but that, obviously, impacts on the range
« Last Edit: 11 May 2011, 14:19:04 by Lazydocker »
Pages: 1 2 [3]  All   Go Up
