Pages: 1 2 [3]  All   Go Down
Author Topic: LPG ecu location  (Read 6693 times)
Re: LPG ecu location
« Reply #30 on: 12 May 2011, 17:36:39 »
Yep... Think mine will be on brackets in the same place as TBE and the loom will be the same as well :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #31 on: 12 May 2011, 18:19:22 »
Mine is in next to the ecu. Looks well smaller than that one though!
« Reply #32 on: 12 May 2011, 18:24:55 »
Depends what brand it is ;) ;)
The STAG 300 ones are about the size of the one I pictured... Behind the bumper is actually a pretty good place to hide it away IMO, completely out of sight and, apart from a little extending of wires and the actual LPG injector wires everything drops in nice and easy and can be reasonably well hidden :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #33 on: 12 May 2011, 20:26:41 »
Mines a koltec and the ecu.s about the size of a fag packet
Martin_1962
« Reply #34 on: 12 May 2011, 20:43:30 »
or how about in the air cleaner.
BODGE
Blocks the airflow, had this problem with my last car, done by a bloddy professional installer - hence the spate of DIY installs
« Reply #35 on: 12 May 2011, 20:44:43 »
If yours is koltec then prey it doesn't go wrong! It's a different animal and what vauxhall used to fit as "Factory Fitted" LPG. Hardly anyone will work on them and parts can be hard to find if you're not near one of the few places that will look at them.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #36 on: 12 May 2011, 21:24:28 »
The original installers are in yorkshire. Had it serviced by them when i bought it, heard they can be tricky. It.s done 125.000 on
Gas so fingers crossed
Ken T
  • Stockport
« Reply #37 on: 13 May 2011, 16:40:14 »
I put my ECU on the bulkhead, behind the steering pump reservoir.
Plenty space to get the wiring out and into my trunking.
Ken
Pages: 1 2 [3]  All   Go Up
