Author Topic: why did vaux change coil pack connectors ?  (Read 1704 times)
SteveT528
« on: 19 May 2011, 19:58:11 »
Hi all, any idea why vaux changed the coil pack connector?
Bosch 0 221 503 017 rounded connector
Bosch 0 221 503 010 square connector
are they the same other than connector? or are they different voltages/resistance?
Re: why did vaux change coil pack connectors ?
« Reply #1 on: 19 May 2011, 20:03:01 »
Probably to cause problems and confuse the issue ::) ::) ;D ;D
SteveT528
« Reply #2 on: 19 May 2011, 20:12:25 »
lol ;D sounds about right  ;D good old vauxhall
« Reply #3 on: 19 May 2011, 20:15:40 »
I suspect its less likely Vx initiated it, probably Bosch found a reason to 'improve' it for some unknown reason.  Possibly because it may be electrically different, and not necessarily cross compatible in all cases?
SteveT528
« Reply #4 on: 19 May 2011, 20:50:39 »
True, forgot bosch made it.  i have a new gen vx square type here that i bought by mistake and i needed the rounded type so... was thinking of changing the connector but ive changed my mind i need to stop being tight and get the right one  ;D
