Author Topic: Tyre profile & ride height question.  (Read 8153 times)
    • 530D M Sport, 330i Coupe
Re: Tyre profile & ride height question.
« Reply #45 on: 24 May 2011, 19:33:31 »
I presume that Courtney have modified the block to address the cooling issues with the power increase?
Be interested to know what they did.
Also is this running on the standard exhaust manifolds?
the alarming man
  • medway kent
    • disco V8
« Reply #46 on: 24 May 2011, 21:01:34 »
and this is a tyre fitter....?
In short :-
yes, the speedo will be wrong - almost 4%, which is quite a large amount.
yes, the car will handle poorly - the suspension geometry is designed around the hub being 11.7 inches from the road. You're moving this up by half an inch, which is a massive amount, affecting handling, grip and stability under both cornering and braking.
seems this thread has gone slightly of topic - was only asking about tyres ;D ;D ;D ;D
I was just asking for opinions on this idea. I would not have gone ahead & done it without some advice from the forum.It was a possibility but maybe not now.  Seems it is not a good idea then 50 profile instead of 45 ?
Would the same bad handling issues occur if you used 18" rims & 40 profile tyres then ? :-/ :-/ :-/ :-/ :-/
looks like you thread as been hijacked!!
Big_Al
« Reply #47 on: 24 May 2011, 21:18:35 »
In short :-
Right outta my depth & too techie now   Mark :o :o
&  I was only asking about tyres  ;D ;D ;D ;D
51M0N
  • Hull
« Reply #48 on: 24 May 2011, 22:19:58 »
Never gets hot so...... pass. not a concern lol
ex manifolds are standard, and restrictive as hell. looking into getting some made. i know someone on an x25xe used ford probe manifolds and welded the flanges on, whether this is possible on an x30 mounted the other way is something of a dark area.
Pages: 1 2 3 [4]  All   Go Up
Page created in 0.048 seconds with 20 queries.
