Pages: 1 [2] 3  All   Go Down
Author Topic: Stag Ac gas synchro link  (Read 7843 times)
Re: Stag Ac gas synchro link
« Reply #15 on: 31 May 2011, 20:09:41 »
« Reply #16 on: 31 May 2011, 20:14:24 »
Gayboy definitely has an 8mm olive in his possession... I found it in his Vapour box ::) :D
Anyway, they're available from a decent DIY store ;) But you've probably got more than 1 of each size... I didn't get as far as actually sorting the spares, just consolidated them ;) ;)
« Reply #17 on: 31 May 2011, 20:17:21 »
Been through every box in the 'bits' box, only those 2 olives.  None in the tubes/wires box are there?
« Reply #18 on: 31 May 2011, 20:22:56 »
Oh... OK ::)
Doubt there's any in the other box TBH... I was being a bit more thorough then, although it is possible :-/ :-/
You can just grab some 8mm olives from a DIY place though... B&Q do them IIRC ;)
« Reply #19 on: 31 May 2011, 20:42:11 »
Ah, dont need olives, join has them in. So just large poly ends and a bit of polypipe.
« Reply #20 on: 31 May 2011, 20:44:49 »
All the ends and olives I have here, and a piece of PF, just shy of 2m, will be in post tomorrow :y
« Reply #21 on: 31 May 2011, 21:01:23 »
Nice one, thnkyou.  :y
« Reply #22 on: 02 June 2011, 21:09:55 »
Fixed it yet, Mr CG?
« Reply #23 on: 02 June 2011, 21:30:10 »
Well.... It runs on gas now. So that's fixed. Cheers TB. That postage couldn't have been cheep either.
 But it wont calibrate, runs like a bag of pants and stalls. Miss fire codes all over the place. Need to book in with Mr Wood I think. Sumats not right, it keeps turning off petrol injectors and, I suspect , turning on gas to the wrong cylinder. Ran out of time tonight so put it all away.
So...
Petrol 1 LPG 1
Petrol 3 LPG 2
Petrol 5 LPG 3
Petrol 2 LPG 4
Petrol 4 LPG 5
Petrol 6 LPG 6
I thought?
« Reply #24 on: 02 June 2011, 22:09:54 »
So...
Petrol 1 LPG 1
Petrol 3 LPG 2
Petrol 5 LPG 3
Petrol 2 LPG 4
Petrol 4 LPG 5
Petrol 6 LPG 6
I thought?
Should be, yes... I do hope you haven't managed to bugger up the piggy back connections as that could be a right PITA to trace ::)
Have you managed to get the Vap pressure to settle correctly yet?
« Reply #25 on: 02 June 2011, 22:22:03 »
So...
Petrol 1 LPG 1
Petrol 3 LPG 2
Petrol 5 LPG 3
Petrol 2 LPG 4
Petrol 4 LPG 5
Petrol 6 LPG 6
I thought?
Will have to check the piggy backs.
Vap pressure is there abouts, although the calibration keeps going tits up saying collector pressure incorrect at 0.63.   Which seems completely at odds with what shows top right of the screen.
« Reply #26 on: 02 June 2011, 22:31:59 »
So...
Petrol 1 LPG 1
Petrol 3 LPG 2
Petrol 5 LPG 3
Petrol 2 LPG 4
Petrol 4 LPG 5
Petrol 6 LPG 6
I thought?
Very curious :-/ :-/ :-/
Have a good check of the colours too (if you didn't before fitting) just in case there's been a balls up with the clips ;) ;)
« Reply #27 on: 03 June 2011, 15:35:03 »
Piggy backs are correct according to stag wiring diags. Not just the number tags but the wiring colours are also correct.
« Reply #28 on: 03 June 2011, 16:08:15 »
Egg sucking - the piggy backs you have wired....
Cyl 1  Piggyback 1  LPG 1
Cyl 3  Piggyback 2  LPG 2
Cyl 5  Piggyback 3  LPG 3
Cyl 2  Piggyback 4  LPG 4
Cyl 4  Piggyback 5  LPG 5
Cyl 6  Piggyback 6  LPG 6
What size are the nozzles?
Is the pressure about right (1.1bar)?
« Reply #29 on: 03 June 2011, 16:36:14 »
Yes that's how LPG injectors are asigned
Nozzles are 2.5
Pressure is 1.1 bar ish on Average but it varies.
During calibration I am only seeing LPG injector active on cylinder 1 to start with. Then 2+3 come in, and simultaneously LPG injectors 456 (cylinder246,bank2) all read zero and it miss fires like a gooden.
« Last Edit: 03 June 2011, 16:37:06 by chrisgixer »
Pages: 1 [2] 3  All   Go Up
