Author Topic: td inlet manifold gaskets  (Read 1739 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 12 June 2011, 21:08:54 »
just got the gaskets needed for my td , is there a way up they should go. eg , the side with the part No facing up (my guess would be it dont matter)  but it may :-/ :y
Omegatoy
  • UK
Re: td inlet manifold gaskets
« Reply #1 on: 12 June 2011, 22:15:28 »
changed loads andnever asked that question!! did mine yesterday and i put them darker side up if that helps!!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 13 June 2011, 00:47:43 »
Same here ........
Just ensure that the mating surfaces are clean, and you should have no problems. ;)
raywilb
    • Citroen C4 Cactus
« Reply #3 on: 13 June 2011, 13:34:48 »
why i asked , is because these new ones i got from a landrover dealer have a rubberised seal around the bore. slightly more pronounced on the dark side. i dont recall them having the seal on the last ones i bought.  :y
