Author Topic: cruise control  (Read 2077 times)
ninjapirate
  • dummer. hants.
cruise control
« on: 12 June 2011, 21:59:13 »
hi, had a quick look around for info
a mate just told me its simple to retro fit cruise control, i just need the stalk and someone with tech2 to program it.
so, is this correct and is there anyone around the winchester hants area wilts, etc that could do that for me?
thanks
pirate
Re: cruise control
« Reply #1 on: 12 June 2011, 22:02:29 »
Yep, stalk and TechII. Kevin may well be your man.
http://www.omegaowners.com/forum/YaBB.pl?action=viewprofile;username=705E4D5255646C54545F3B0
Got a stalk here if you need one ;)
ninjapirate
  • dummer. hants.
Re: cruise control
« Reply #2 on: 12 June 2011, 22:09:25 »
awsome!
so i dont need any other parts? actuator or anything?
kevin is just down the road in alton too!
cruise would be great, stops me sitting too high a speed and getting poo mpg lol
Re: cruise control
« Reply #3 on: 12 June 2011, 22:23:57 »
awsome!
Nope, just stalk & TechII :y
ninjapirate
  • dummer. hants.
Re: cruise control
« Reply #4 on: 12 June 2011, 22:26:09 »
wooop! loving that.
so how much for some stalkage?
Re: cruise control
« Reply #5 on: 13 June 2011, 08:23:32 »
If yours is a manual, you *may* need a clutch switch (can't remember if 2.2s have them fitted already), you need to visually check first.
Kevin Wood is the nearest to you with the equipment to enable it in the 2.2 ECU.
ninjapirate
  • dummer. hants.
Re: cruise control
« Reply #6 on: 13 June 2011, 12:45:23 »
am i looking for a switch type thing at the top of the clutch pedal? will check when i try sort the seat height, i feel very hungover today pmsl
Re: cruise control
« Reply #7 on: 13 June 2011, 12:55:56 »
yup :y
Re: cruise control
« Reply #8 on: 13 June 2011, 15:23:32 »
I needed a clutch switch, use cruise all time now. Never a time out when I don't use it really!  :)
ninjapirate
  • dummer. hants.
Re: cruise control
« Reply #9 on: 13 June 2011, 15:52:19 »
had a quick look, couldnt see much, but didnt remove that black cover thingy, will do tht and grab a pic i think.
i use cruise all the time in the alfa so its def worth getting it fitted for me, esp as i want to use it for towing to cornwall.
