Author Topic: Tacho reading without ABS module!!  (Read 2652 times)
MartinP
  • Dudley
    • BMW 320D
« on: 13 June 2011, 22:29:00 »
Once again, for the kit car  :)
This is the drawing for the Tacho  :-?
How do I rig this up to the V6, to give me a reading? Where do I have to pick the feed up from?
The gauge supplier got a bit vauge when I told him there were 3 coils and said "I would rather you tell me how it is going to be connected"
Any help appreciated.
Martin
Re: Tacho reading without ABS module!!
« Reply #1 on: 13 June 2011, 22:34:42 »
Can't remember which V6 engine you're using but perhaps an injector feed as you're not having the ABS? :-/ :-/
I would think that either Kevin or 2woody will be the best bet ;) ;)
MartinP
  • Dudley
    • BMW 320D
« Reply #2 on: 13 June 2011, 22:50:44 »
There only one V6  :D on here  :y
If I only get 1 coil input per revolution, presumably  the Tacho dip switches input the calculation factor to get the correct reading.
The wiring diagram I have put up is for the 100mm unit, I now have to go back as the 80mm unit did not show the selectable dip switches.
will try to get the other drawing up soon as.
Martin
« Reply #3 on: 14 June 2011, 08:32:44 »
Er, you cant easily.
The only possible might be to diode OR the three ignition coil feeds together and add a pull-up resistor.....got to be careful with back EMF though!
« Reply #4 on: 14 June 2011, 14:41:41 »
Looks like the same VDO one that I have.
If so, it'll work fine from the ECU tacho output signal that normally feeds the Omega dash (light green wire IIRC). It doesn't need to be fed from a coil. Select 6 cylinders on the dip switch. :y
MartinP
  • Dudley
    • BMW 320D
« Reply #5 on: 14 June 2011, 21:46:26 »
Thanks both, I will try and find the output from the ECU then.
Martin
« Reply #6 on: 14 June 2011, 22:22:21 »
Pin 43 on the ECU (Green wire). :y
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 14 June 2011, 23:22:46 »
Thanks Kevin, I spent 10 minutes looking at the drawing and couldn't see that for love nor money  ::)
Does the output send a true pulse or a fraction?
The 100mm ETB clocks are cylinder selectable not sure about the 80mm.
Martin
Martin_1962
« Reply #8 on: 15 June 2011, 08:16:02 »
Martin
Green wire well know among LPG installs :) :)
« Reply #9 on: 15 June 2011, 09:27:30 »
Martin
It's one (12V IIRC) pulse per ignition event so configure the tacho for 6 cylinders and it should work.
« Reply #10 on: 15 June 2011, 10:24:14 »
I thought the tacho was a multiple....maybe thats the speed signal then lol (which is why I didn't sudgest it)
« Reply #11 on: 15 June 2011, 11:54:01 »
I think I scoped it when doing the first LPG conversion. The LPG ECUs seem happy with it at any rate.
MartinP
  • Dudley
    • BMW 320D
« Reply #12 on: 15 June 2011, 23:08:05 »
Thanks for the info.
Spoke to ETB today, bloke was happier to know the signal was coming from the ECU.
He thinks the Vaux ECU will send a 12v square wave signal, so will configure the Tacho for a V6 and we will see how we go.
Will be calibrated at their works and can be changed if its not right.
I had terminated the Green wire as I thought I didn't need it. Extended it tonight to get it to the dash.
Martin
