Author Topic: AbS/TC  (Read 1841 times)
smurfdjman
  • Inchinnan,Renfrew,Scotland
AbS/TC
« on: 19 June 2011, 21:54:53 »
hi guys and Girls
im on about these ABS/TC lights again.My understanding is that the ECU is Knackered, but if it is needing burnt out wiring redone why does the lights go out and the speedo come on now and again. and can i use the cheapo tech2 usb to OBD2 from ebay to reset or check it
Re: AbS/TC
« Reply #1 on: 19 June 2011, 22:19:01 »
A single tiny wire that is bonded in a special way fails ... as the wire is packed in gooey plastic substance it makes intermittent contact .. when mine went it appeared to be affected by what I assumed to be the internal temperature of the ECU .. it would not work when cold, work a bit when slightly warm and not work at all when well warm.. and slowly but surely the "not working" bracket was getting bigger and bigger. As the power steering was affected I opted to get it fixed !!!
Re: AbS/TC
« Reply #2 on: 19 June 2011, 22:38:21 »
Not really worth messing about with surely?  It's only going go get worse.
Varche
  • middle of Andalucia
    • Golf Estate
Re: AbS/TC
« Reply #3 on: 20 June 2011, 12:32:56 »
If yours is a 2.5 auto, I have one that I paid to have refurbished at Nottingham ECU testing but haven't since used. I no longer need it as I am sadly breaking the car. shouldn't need tech 2'ing as it was off a car with cruise etc. Comes with companies guarantee .. Would just need to agree a price!
Could post recorded delivery to you from Spain :y
