Author Topic: Spring Assistors  (Read 2528 times)
deltaman
  • South Lincolnshire
    • 03 omega CD 2.2
Spring Assistors
« on: 22 June 2011, 17:53:45 »
I tow a caravan with my 2.2, when loaded the rear drops very low causing the jockey wheel on the caravan to catch the road on an uneven surface.
I have had new springs fitted and new shocks, I have checked the nose weight of the loaded van and it is just under the recomended figure of 75kgs.
My next thought was to fit spring assistors, has anyone any experiance of having done this, I was concerned about the ride after fitting
    • 530D M Sport, 330i Coupe
Re: Spring Assistors
« Reply #1 on: 22 June 2011, 17:57:30 »
Yep, we have spring assistors fitted to our DTi Estate (also has new shocks and springs as the 130K originals were a little tired). Seems to help maintain a nice level ride with the caravan attached but I generally take the jockey wheel off completely when towing as it's one less thing to fall off!  ::)
Ride quality in the car is unaltered when you aren't towing.
« Last Edit: 22 June 2011, 17:58:13 by VXL_V6 »
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #2 on: 22 June 2011, 20:14:29 »
a set of graystons should sort yyou out
try a caravan dealer or outdoor shop
dieseldonicely
Martin_1962
« Reply #3 on: 23 June 2011, 00:10:57 »
Monroe air adjustable shocks work well :y :y
« Reply #4 on: 23 June 2011, 00:17:33 »
Perhaps we should swap springs, mine is so high in the air it looks daft.... ::) ::) ::)
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #5 on: 23 June 2011, 00:27:21 »
Blimey!    Do they still make Monroe Air Shocks.  Wow!  :o
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Martin_1962
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 23 June 2011, 09:50:55 »
Deltaman. Couple of things.
Buy a nose weight gauge. Money well spent. The caravan we had was nose weight of 75Kg or more. The saloon is max of 75Kg. Towsure or similar.
I have spring assistors fitted now andf it doesn't seem to affect the ride unladen. Laden with bags of cement, fertiliser etc it is good.
The only concern I have is that they may cause more load on the "not locked by rubber" parts of the coil spring and cause them to fail prematurely. I haven't any evidence to back that up though.
Bixy1
    • Cats Tails
« Reply #8 on: 23 June 2011, 23:45:34 »
I last used them on a 72'  MK1 Granada. about 25 years ago. They were great!  :y
2woody
  • Northumberland
« Reply #9 on: 24 June 2011, 10:46:57 »
I have a spare set of rear springs with assistors. From genuine GM "rough-road" package.
yours for £20 + postage
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
« Reply #10 on: 24 June 2011, 12:26:57 »
I got some Monroe shocks from Monroeshop.co.uk a while ago. They were cheaper than ebay iirc. They work well. As said.
I used to know everything. Then I got married.
deltaman
    • 03 omega CD 2.2
« Reply #11 on: 24 June 2011, 19:17:15 »
Thanks all for your replies, we have a nose weight gauge so we are ok with the loading, having had new springs and shocks fitted we will have a go with the assistors and see what happens, just spoilt I guess having towed with a 4x4 for many years.
Page created in 0.026 seconds with 20 queries.
