Pages: 1 2 3 4 5 6 7 [8]   Go Down
Author Topic: multi ram removal, rip it out...leave it alone....  (Read 19362 times)
Re: multi ram removal, rip it out...leave it alone....
« Reply #105 on: 01 July 2011, 23:36:15 »
Just to let you know the 'modified' dyno graph is the 3.0 and the 'standard' is from a 3.2........
Which there's actually pretty much nothing between... Certainly on the road ;) ;)
« Reply #106 on: 02 July 2011, 08:20:31 »
Just extend the ram air pipes already attached to them. Flexi hoses running out to the front to catch plenty of cold air. ;)
Would imagine a set of gixer750 bodies might be a bit small for a 3.2 v6 ?
Also, not sure about the newer models but the earlier ones had a dual butterfly setup per pot. Throttle, then under that a second to try and smooth the incredibly snatchy pick up from zero throttle. Which on a bike, cranked over, ESP in the wet, is NOT what you want. It was still impossible to feed the power in smoothly, and Suzuki sold their admission that they couldnt tune it out as a revelation.  >:(
Anyway, I doubt the complication of a second butterfly would be helpful. As it's not an issue on a car with a better map anyway (it couldn't be any worse than suzukis)  >:( I'd choose another set from a maker that knows what they're doing. Unless the newer ones where sorted...?
« Reply #107 on: 02 July 2011, 09:45:12 »
In standard form, there is little between the 3.0 and 3.2
« Reply #108 on: 04 July 2011, 11:45:22 »
You can just ditch the second butterfly and seal the holes where the shaft was.
Perhaps this is the reason they are so readily available? Lots of bikers ditching them and fitting carbs?
Another problem is the take-off for the MAP sensor is far too close to the throttles, IIRC, and gives a very poor "all or nothing" signal so that may have been part of the problem with the original application?
Sample the MAP from further into the intake and they work nicely, by all accounts.
« Last Edit: 04 July 2011, 11:45:59 by Kevin_Wood »
« Reply #109 on: 04 July 2011, 12:47:47 »
May well be. There wasn't a solution available at the time and the bike is long gone now thank god. As I recall it was an inherent problem in early days of fuel injection on bikes. But Suzuki suffered especially badly.
Just couldn't feed the power in smoothly. Being sooo careful with opening the throttle, everyone else had buggered off and the apex was long gone by the time it was on the power safely. Some just went "bang" and wacked the throttle open regardless. I rode other gsxr 1000's which all felt the same to me around that year 00/01... and later 02/03 models.
Current 04 fireblade has no such issue btw.  :y
I'd be interested to see how this lot would fit in the v though?
« Last Edit: 04 July 2011, 13:02:36 by chrisgixer »
« Reply #110 on: 04 July 2011, 13:00:05 »
Hmmm, that's a shame. Was hoping these would work but they appear to be cast in pairs. http://www.roadracingworld.com/enlarge/?section=news&image=709
Although not sure if variable inlet length is so important on a low revving engine anyway?
mr carl
« Reply #111 on: 04 July 2011, 13:07:13 »
Sweet but with 6 pots wouldn't it be easier to buy single throttle bodies?
« Reply #112 on: 04 July 2011, 15:05:51 »
It is, but they're probably about a foot too short, as a result of the reduced RPM. Nice, though. :-*
Pages: 1 2 3 4 5 6 7 [8]   Go Up
