Author Topic: New BMW is goosed! enjeneer needed  (Read 5120 times)
Re: New BMW is goosed! enjeneer needed
« Reply #15 on: 05 July 2011, 22:02:18 »
Helicoils are crap on anything other than something that is bolted up after repair & then never ever touched. Although I've never used a spark plug Time-sert I've used loads of M5 M6 etc Time-serts, their advantage is that the thread is a solid one piece insert that doesn't unwind from the hole.
http://www.youtube.com/watch?v=Ntiy8L97Nco
russ0205
  • northants
    • mondeo
« Reply #16 on: 05 July 2011, 22:12:33 »
Take the risk helicoil it then sell it on the same as a lot of traders do, In a lot of opinions you havn't bodged it,
  :y :y :y :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #17 on: 05 July 2011, 22:15:23 »
agreed on helicoils,no good on threads that will be used again,not come across the time-sert's before but they look pretty good :y
other rides
« Reply #18 on: 05 July 2011, 22:18:26 »
Agreed  time-sert is the way to go ..
http://www.timesert.com/
and specifically for plugs
http://www.timesert.com/html/sparkplug.html
and for previously bodged repairs ...
http://www.timesert.com/html/bigsert_sparkplug.html
« Last Edit: 05 July 2011, 22:21:19 by entwood »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #19 on: 05 July 2011, 22:20:35 »
Seen the timeserts Andy but not come across an engineering shop who has said they would have a go, they all seem to be helimad you know anyone who could do it down your way?
« Reply #20 on: 05 July 2011, 22:21:20 »
...,not come across the time-sert's before but they look pretty good :y
They're not cheap though. I've a set that covers M5 M6 M8 M10 & M12 which I believe cost my previous employer around £300 ............. part of the redundancy package  ::) ::) ::)
« Reply #21 on: 05 July 2011, 22:23:56 »
You were busy Nige!  :y :y :y :y
« Reply #22 on: 05 July 2011, 22:26:04 »
I try .....  ( or is it I'm trying ??  :)  :)   :)  )
« Reply #23 on: 05 July 2011, 22:27:17 »
Sorry, afraid not. I only know about the Time-sert plug inserts while looking for the 'normal' inserts part numbers.
Maybe contact Time-sert asking who they've supplied in the Liverpool-ish area  :-/ :-/ :-/
« Reply #24 on: 05 July 2011, 22:44:22 »
Saw timeserts used a few years back on an Imp engine used for saloon racing. Apparently after a plug change one of them was cross threaded and it "blew", damaging the thread.
Done in-situ and the car was racing again in less than 2 hours.
 IIRC the major downside was the cost of the tools.. the inserts themselves were not too expensive ... but the tools ....  :(
Re-tapping the hole was done in very small amounts and copious volumes of grease were used to collect swarf .. the guy obviously knew what he was doing.
I "believe" they are considered a DIY method not neccessarily a workshop one .. but the cost of the tools might preclude a "one off" .. :(
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #25 on: 05 July 2011, 22:55:53 »
have piston at the top have it tapped and helicoiled
then use hoover with adapted pipe we use 8mm fuel pipe taped to hoover pipe hoover debris out
« Reply #26 on: 05 July 2011, 22:59:07 »
..... but the cost of the tools might preclude a "one off" .. :(
but the cost of the Time Sert tools vs the price of A N Other head and fitting it etc  :-/ :-/ :-/
« Reply #27 on: 05 July 2011, 23:02:55 »
there are a few spark plug Time Sert kits here ....  but as said, they're expensive.
http://shop.ebay.co.uk/i.html?_nkw=time+sert&_sacat=0&_odkw=plastic+welder&_osacat=0&_trksid=p3286.c0.m270.l1313
