Author Topic: Rear view cameras  (Read 3680 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Rear view cameras
« on: 03 July 2011, 08:50:25 »
Morning all,
has anyone fitted one of these and are they any good? I found one on the flea of bay that I'm considering possibly.
I'm only interested as it would make hooking up to the 'van a tadge easier  ::)
TIA  :y
AKA - Mr Bracket
Re: Rear view cameras
« Reply #1 on: 03 July 2011, 09:39:17 »
Must admit, I'd be tempted to fit one for a hitching aid but just feel it's too much to spend for just that purpose :-/
blackviper90210
« Reply #2 on: 03 July 2011, 12:46:48 »
Ditto. The one on the auction site is for £37 ono +£4 p+p, so not too expensive, but it is when your literally counting pennies to get by each week, lol.
AKA - Mr Bracket
« Reply #3 on: 03 July 2011, 12:52:35 »
Or you could learn to reverse park?  ::)  :-X :-X  ;D ;D
blackviper90210
« Reply #4 on: 03 July 2011, 12:54:33 »
Ouch, lol.
I can do that, just don't fancy actually parking the 'van literally in the boot though!!  ::)
AKA - Mr Bracket
« Reply #5 on: 03 July 2011, 14:18:06 »
I guarantee I'd get into a smaller space than you ;) ;)
I only considered it as a hitching aid TBH, and would want to be able to get the image on the CID (which I know isn't possible/viable ;)) so not bothering ;)
I'll eventually get around to fitting a bumper protector plate, but I don't want one that's fitted permanently as I think they're a bit of an eyesore
« Reply #6 on: 03 July 2011, 14:20:29 »
Music to Pinks ears?  ::)  ;D ;D ;D ;D
« Reply #7 on: 03 July 2011, 14:41:43 »
;D ;D ;D ;D
But that's no small space :-X :-X ::) ::) :D :D
« Reply #8 on: 03 July 2011, 14:47:29 »
;D ;D ;D ;D
Guessing you've got 'first hand' experience with that then?  :o :o :o  ;D ;D ;D
No doubt you could park 'van better than me, legally I would not be allowed to  :(
« Reply #9 on: 03 July 2011, 15:19:37 »
;D ;D ;D ;D
Meant the car on it's own TBH... But the 'van isn't a fair comparison as I've done it for years and also done lots of trailer work :y
blackviper90210
« Reply #10 on: 03 July 2011, 16:21:11 »
;D ;D ;D ;D
Same here!
There is quiet satisfaction in getting a 40ft artic in a tight spot, then seeing others in a supermarket car park make several attempts to park an average car!
I have to chuckle, it's amazing how many cant't reverse and drive nose in and totally screw it up  ;D ;D ;D ;D ;D ;D
AKA - Mr Bracket
« Reply #11 on: 05 July 2011, 09:22:09 »
;D ;D ;D ;D
Meant the car on it's own TBH... But the 'van isn't a fair comparison as I've done it been a pikey for years and also done lots of trailer work :y
I reckon it could be wired up to the CID pretty easily, TBH. Would need a box to convert the output to RGB and perhaps a sync separator. Probably not worth the while.
I don't find it too hard to reverse up to a hitch and get it close enough to couple up. It's just stopping before it cracks the number plate. ::)  Perhaps a little infra-red beam across the number plate recess would be the best solution?
« Reply #12 on: 05 July 2011, 09:34:48 »
;D ;D ;D ;D
;D ;D ;D
Except in an estate the number plate isn't there ;)
I know it "could" possibly be wired into the CID but it's a lot of work and not sure there's anywhere easy to hide the box of tricks ;)
TBH, I'm thinking of getting a heavy duty, removable hitch protector as it would make it much easier.
Other problem with the caravan is that if you have reversed it into position, sometimes the hitch will creep forwards once removed (if you forget to pull forwards a touch again) and press onto the bumper ;)
scimmy_man
  • yorkshire
« Reply #13 on: 05 July 2011, 15:46:49 »
A mate of mine, made two old aerials with clips on,
one on the towball one on the hitch, reverse up until they touch, you are over the ball.
I told him to patent it.
« Reply #14 on: 05 July 2011, 16:48:01 »
you could use two of these, one on the hitch & the other on the flat at tthe top pf the tow ball  ;) ......  :y
